What is the relationship between energy and position in quantum mechanics?
  • Context: Graduate
  • Thread starter Thread starter Sacroiliac
    Energy Qm
The discussion explores the relationship between energy and position in quantum mechanics, specifically in the context of the hydrogen atom's 1s orbital. Participants examine how the defined energy of the electron contrasts with its probabilistic position, touching on concepts such as wavefunctions, uncertainty principles, and tunneling.
  • Some participants note that the 1s orbital of the hydrogen atom has a defined energy of 13.6 eV, while the probability density suggests the electron can be found at various distances from the nucleus.
  • There is a question about whether the law implies that the electron can be found throughout this range of positions.
  • One participant suggests that the exact energy can coexist with variable position due to the relationship between position and momentum, where variations in momentum compensate for variations in position.
  • Another participant elaborates that the probability density decreases with distance from the nucleus but never reaches zero, allowing for tunneling into classically forbidden regions.
  • There is a discussion about how the Heisenberg Uncertainty Principle (HUP) relates to the electron's potential energy and momentum as it approaches the nucleus.
  • Clarifications are made regarding the spread of the electron's wavefunction in both position and momentum space, affecting the definition of its energy.
Participants express varying interpretations of how energy and position relate in quantum mechanics, with some agreeing on the general principles while others seek clarification on specific points. The discussion remains unresolved with multiple competing views on the implications of the uncertainty principle and the behavior of the electron.
Limitations include the reliance on interpretations of quantum mechanics, the complexity of wavefunctions, and the implications of the uncertainty principle, which are not fully resolved in the discussion.
Sacroiliac
In the hydrogen atom the 1s orbital has a clearly defined energy of 13.6 eV, but the probability density and radial probability density says you are liable to find the 1s electron anywhere from the nucleus on out.
How does this exact energy value jive with this variable position?
does the law really say that the electron can be found in this range?
The energy of the atom
can be exact with the position not being exact because the canonical conjugate to the the position, the momentum, also varies. To put it very crudely, the variation in the momentum compensates for the variation in position, allowing the energy to have an exact value.
That's about as good an answer as I can come up with under the circumstances, but when you learn a little more about wavefunctions and operators and such you'll understand it better.
Yes. That's quite correct. The probability density decreases as you go further from the nucleus of the atom but it never becomes zero. The electron can tunnel into the potential barrier, i.e. into the classically forbidden regions. The farther it travels into such a region the shorter the time it stays there. The time-energy uncertainty principle implies that the ectron will not stay outside the barrier for a time equal to or greater than the time it takes to measure an energy violation.
Pete
Are you saying that as the particle gets closer to the nucleus its potential energy decreases but because it is more localized the HUP causes its momentum to increase and exactly offset the decrease in Potential energy?
PMB I didn't understand your post. Sorry.
I did say that was a very crude description, but the basic idea is correct. You see, we can't really say the electron has a specific momentum or position because its wavefunction is spread out in space around the proton. But while it is spread out in both coordinate space and momentum space the phase of its amplitude changes with time at a constant rate, so its energy is well defined.
  • · Replies 43 ·
  • · Replies 21 ·
  • · Replies 47 ·
  • · Replies 20 ·
