Bus Topology: Connecting Computers to the "Bus
  • Thread starter Thread starter Math Is Hard
    Bus Topology
The discussion centers around bus topology in networking, specifically how computers connect to a shared transmission line, the physical layout of such connections, and the implications of different configurations like star topology. Participants explore theoretical aspects, practical setups, and historical context related to bus networks.
  • Historical
  • Some participants describe bus topology as a simple network organization where all computers connect to a single transmission line, typically coaxial cable.
  • There is confusion about how devices connect to the bus, with some suggesting T-connectors as a solution.
  • Participants discuss the differences between bus and star topologies, noting that a bus allows a voltage to be seen by all connected interfaces, while a star configuration requires a hub or switch.
  • Some participants mention daisy-chain and stub connections as methods for connecting devices to a multi-drop bus, with specifications varying by network type.
  • Clarifications are made regarding the meaning of "multi-drop" and "stubs," with some participants explaining that multi-drop involves multiple transmit and receive nodes.
  • Historical context is provided about coaxial cable setups, specifically referencing 10Base-2 (thinnet) as a traditional bus design.
Participants express varying views on the best way to visualize bus topology and its connections, with no consensus reached on the optimal diagrammatic representation. There is also ongoing discussion about the roles of hubs and switches in network configurations.
Participants note limitations in understanding the physical layout of bus topology and the implications of different connection methods, as well as the historical context of network designs.
Math Is Hard
Staff Emeritus
http://en.kioskea.net/contents/initiation/topologi.php3
Bus topology is the simplest way a network can be organised. In bus topology, all computers are linked to the same transmission line by using a cable, usually coaxial. The word "bus" refers to the physical line that joins all the machines on the network.
What connects the cables coming from the computers to the "bus"? I can't quite get the idea of connecting these cables to another cable when connecting devices aren't mentioned.
Computer science news on Phys.org
The bus is just the cable running between each computer.
Like an ethernet cable - it's called a bus when it's shared (like the original ethernet) it would be better drawn with the wire looping form one machine to the nex
Thanks, MGB. So would it actually look more like this if it was physically set up?
Ironically it would be better to draw it as a star. The point of a bus is that a voltage on it is immediately seen by all interfaces connected to the bus.
(A star network is different - there is usually some logic in the hub to control where the data goes)
hmm.. I'm having trouble drawing it as a star configuration without a hub (or switch) since, as you said, then I have a star topology. I less trouble envisioning it wirelessly, but I know that these networks were originally set up using coaxial cable, so there must be a way to diagram that design.
Do you mean a switch? From what I've been reading, hubs seem pretty dumb, just sending the data on to every other host on the network. But I think you could have either a hub or a switch to connect the star network (I don't know this for sure).
Thanks again for your help.
I found the solution. The cables can be connected to other cables with T-connectors.
The two choices for connecting your devices to a multi-drop doubly-terminated bus are Daisy-Chain or with stubs.
For a given network type, there will be a specification for how long the stubs can be. For RS-485, for example, zero-length stubs (Daisy-Chain routing of the network twisted pair) are mandatory. For some networks, like the 78kbps control network that my company makes transceivers for, the stubs are allowed to be up to 3 meters long.
Thanks, Berkeman. What is meant by "multi-drop" and what are "stubs"?
Your cat is scaring me. But I'll try to answer under duress... :-p
Multi-drop means more than one TX node and one RX node. Two nodes is point-to-point at the ends of the DT bus, which is regular Ethernet comm. >Two nodes is multidrop.
But in control networks and other specialized networks, you want up to 64 nodes all working together, and that's when the multidrop 64 node network comes into play.
And sorry. Stubs are the short lengths of twised pair cables that you use to connect the main bus TP to the nodes. They need to be electrically short,
Thanks mucho. I'll change my avatar later. Just for you. :wink:
Bingo, and you got it right in your first diagram.
Called 10Base-2, or thinnet, the cabling was coax, and it ran a straight line, with terminators at either end. Tapping into the cable via T-connectors were leads which went to the coax cards in every computer.
That was truly the last true "bus" design in the business, as all others offer some sort of hub and spoke design, with 10Base-T being the first, basic hub, rebroadcasting data arriving at one port to all ports.
A switch simply applies some intelligence, figuring out from the packet whether to send it to a specifically intended receiver, to that receiver, or whether to rever to hub mode and broadcast. Layer 3 switches went a step further, but that's getting beyond the scope of the question!
Yes - both hubs and switches are star topology networks.
  • Sticky
9K
