Solving Vector Problems: Displacement and Magnitude Calculations
  • Thread starter Thread starter schrodingersequation
    Vector
The discussion focuses on solving vector problems involving displacement and magnitude calculations. The jogger's first displacement A is 2.50 km due south, and the second displacement B is determined to be 2.80 km. The resultant displacement A+B has a magnitude of 3.75 km and points 48.188 degrees east of south, while A-B also has a magnitude of 3.75 km and points 48.188 degrees west of south. The calculations utilize the Pythagorean theorem and inverse tangent functions to determine the magnitudes and directions of the resultant vectors.
  • Understanding of vector quantities and their properties
  • Familiarity with the Pythagorean theorem
  • Knowledge of trigonometric functions, specifically inverse tangent
  • Ability to perform calculations with significant figures
  • Study vector addition and subtraction techniques
  • Learn about the Pythagorean theorem in two dimensions
  • Explore trigonometric functions and their applications in physics
  • Practice solving real-world problems involving displacement and vectors
Students and educators in physics, mathematicians, and anyone interested in mastering vector calculations and displacement problems.
A jogger travels a route that has two parts. The first is a displacement A of 2.50 km due south, and the second involoves a displacement B that points due east. (a) The resultant displacement A+B has a magnitude of 3.75 km. What is the magnitude of B, and what is the direction of A+B relative to due south? (b) suppose that A-B had a magnitude of 3.75 km. What then would be the magnitude of B, and what is the direction of A-B realtive to due south?
:rolleyes:
I have an answer for this problem I just want to know if it is right.
(a)The magnitude of B is 2.80 km
A+B points 48.188 degrees East of South
(b)the magnitude of B is 2.80 km
A-B points 48.188 degrees West of South
Looks pretty good. In finding the direction, I got the angle to be 48.190. Make sure you're not using rounded values, in fact you can just use cosX = 2.50/3.75, and solve for X (which is what I did). However, you should round to 3 significant digits, giving you 48.2 anyways, which would be the same using my number or yours.
Your answer is correct! Good job solving this vector problem. It's important to remember that displacement is a vector quantity, meaning it has both magnitude and direction. In part (a), the magnitude of B can be found by using the Pythagorean theorem to find the missing side of a right triangle (3.75^2 = 2.50^2 + B^2). And the direction of A+B can be found by using the inverse tangent function to find the angle between the resultant displacement and the due south direction. Similarly, in part (b), the magnitude of B can be found using the same method, and the direction of A-B can be found by subtracting the angle between A and B from 180 degrees. Keep up the good work!
13K
