Show that ____ is a solution to the differential equation model?
The discussion revolves around a differential equation model describing the motion of a spring, where the displacement from the spring's natural length is represented by x, with k as the spring constant and m as the mass. The specific problem involves demonstrating that a given function, x(t)=sin(sqrt(k/m)*t) + 2cos(sqrt(k/m)*t), is a solution to the differential equation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the process of taking derivatives of the proposed solution and express confusion about simplifying terms involving the spring constant and mass. There are questions about the application of the chain rule and how to handle constants in differentiation.
The discussion is ongoing, with participants seeking clarification on the differentiation process and the assumptions made regarding the function x. Some guidance has been offered regarding the use of the chain rule, but there is no explicit consensus on the approach to take.
Participants are grappling with the specifics of differentiation in the context of the problem, and there is an indication of uncertainty regarding the assumptions made about the function x and its derivatives.
thename1000
Trying to go over this part of my test review. I'm not understanding how to do this. The specific problem which I actually have worked out in my notes:
A diff equation model of the motion of a spring where x is displacement from the spring's natural length, k is the spring constant, and m is the mass as follows:
(d^2*x)/(d*t^2) = k/m * x
Show that x(t)=sin(sqrt(k/m)*t) + 2cos(sqrt(k/m)*t) is a solution to the model.
My notes appear to take the first, then the second dir. of the second function there. But that's all I can make sense of. Maybe I'm not understanding how to take the dir of these functions I'm not sure.
For example on the second to the last line, how am I supposed to simplify -k/m (sin(sqrt(k/m)t) + 2cos (sqrt(k/m)t)
to
-k/mx
thanks for any help!
Because you just said that x=(sin(sqrt(k/m)t) + 2cos (sqrt(k/m)t) ?
uhhh...thanks? Since somebody answered I won't get a real answer now. :(
Uhh... that was a real answer?
Notice how you assume that x is sin(sqrt(k/m)*t) + 2cos(sqrt(k/m)*t) to start your answer.
to
-k/mx
Notice how you want to replace the bolded portion with x. Notice how x is assumed to be exactly the bolded portion.
Yes, I see what you're saying, sorry.
I gave the second to the last line as an example of how I don't fully understand the process.
To take the derivative or second derivative of the function do I sub something for sqrt(k/m)?
sin(u*t) + 2cos(u)*t
Like that?
You can but you should be able to use the chain rule without having to substitute like that. It is, after all, just a constant: the derivative of f(ax) is af '(ax).
