How Do You Calculate the Volume of an Arch Dam Using the Shell Method?
  • Thread starter Thread starter Sentral
    Volume
The discussion focuses on calculating the volume of an arch dam using the shell method, specifically for a rotation of 150 degrees around an axis of 150. The user plans to split the cross-section into two triangles and one rectangle, applying the shell method to each section. The integral used is 2π∫[(x+220)(0.03x² + 7.1x + 350)] from -70 to -16, adjusted for the 150-degree rotation by multiplying by (150/360). The approach is confirmed to be on the right track for calculating the volume.
  • Understanding of the shell method in calculus
  • Familiarity with integral calculus and definite integrals
  • Knowledge of geometric shapes, specifically triangles and rectangles
  • Ability to manipulate algebraic expressions and functions
  • Study the application of the shell method in volume calculations
  • Learn how to set up and evaluate definite integrals
  • Explore the geometric properties of arch dams and their cross-sections
  • Review the concept of volume fractions in relation to partial rotations
Students studying calculus, particularly those focusing on volume calculations using the shell method, as well as educators teaching geometric applications in mathematics.
Sentral
The problem is number 4 at this link: http://college.cengage.com/mathematics/larson/calculus_early/2e/students/downloads/mws6a.pdf
The axis of revolution is 150 and the rotation is 150 degrees.
Using the shell method.
My offset is x+220.
The equations that make up the cross section:
[tex].03x^2+7.1x+350[/tex]
[tex]-6.593x+389[/tex]
[tex]389[/tex]
I planned on splitting the cross section into three parts, which are the 2 triangles and rectangles, and apply the shell method on each of these. So first I did [tex]2pi*Integral[(x+220)(.03x^2+7.1x+350)][/tex] with the bounds being -70 to -16. Then I multiplied this answer by (150/360) since it's only 150 degree rotation. In each of my applications of the shell method, the p(x), or the distance to the axis of revolution stayed at x+220. Am I on the right track if I do this for each of the 3 sections?
Welcome to PF!
Hi Sentral! Welcome to PF! :smile:
(have a pi: π and an integral: ∫ and try using the X2 tag just above the Reply box :wink:)
I'm not sure what you're doing (what's 220? :confused:) …
the shell method involves finding the volume of the arc-shaped slice (it will be 150/360 of the volume of a complete cylinder) from x to x + dx …
it will be something times dx …
and then integrating. :smile:
  • · Replies 16 ·
