Finding the initial velocity of a projectile so that it hits a moving object
The problem involves calculating the initial velocity of a projectile launched at an angle of 72 degrees to hit a moving object that is 92 meters away and approaching at a speed of 6 m/s. The projectile is subject to gravitational acceleration of -9.8 m/s².
  • The original poster attempts to apply kinematic equations to determine the necessary velocity for the projectile. Some participants suggest breaking down the motion into horizontal and vertical components, while others question the accuracy of the equations presented.
The discussion is ongoing, with participants exploring different interpretations of the kinematic equations. There is a suggestion to write separate equations for the projectile's horizontal and vertical movements, but no consensus has been reached on a specific approach or solution.
There are indications of confusion regarding the correct application of kinematic equations, and some posts have been deleted, which may affect the continuity of the discussion.
bermy_son92
Object is 92m away from the projectile's launch position and is moving towards the launch position at 6m/s.
The projectile is launched at an angle of 72 degrees towards the moving object.
What must the projectile's velocity be if it is to hit the object moving towards it.
(Both the projectile and object start moving at the same time.)
acceleration = gravity = -9.8m/s
distance=velocity/time
distance=velocity*time+0.5*acceleration*time^2
velocity2 - velocity1 = 2*acceleration*distance
velocity2 = velocity1 * acceleration * time
I tried a few attempts however none of my ideas worked
Why were the 5 or so subsequent messages posted here deleted?
I uh... don't know. I'm new here. Don't know who could do that.
I consider glitches, means, motive, and opportunity.
Until we get the posts back...
Note that your last two equations are wrong. The second-last one should be v2^2-v1^2=2ad, not v2-v1=2ad. The last one should be v2=v1+at, not v2=v1*a*t.
To solve this problem, write separate equations for the projectile's horizontal and vertical movements. In the y direction, the projectile leaves at speed=vsin72 and returns to its original height upon hitting the target. Suppose this takes time t. In the x direction, the projectile's relative speed to the target must be enough to cover 92 m in time t. Can you now write out two equations for the projectile's motion?
28K
  • · Replies 53 ·
