Can U-Substitution Prove This Trigonometric Integral Identity?
  • Thread starter Thread starter Samuelb88
The forum discussion focuses on proving the trigonometric integral identity: \(\int_0^{\pi} x f(\sin x) \, dx = \frac{\pi}{2} \int_0^{\pi} f(\sin x) \, dx\) using the substitution \(u = \pi - x\). The user attempts to transform the left integral into the right but encounters difficulties. The correct approach involves recognizing that the transformed integral can be expressed as \(\int_0^{\pi} (\pi - u) f(\sin u) \, du\), which simplifies the proof. The key insight is that the variable \(u\) can be renamed back to \(x\) for clarity.
  • Understanding of definite integrals and properties of integrals
  • Familiarity with trigonometric identities, specifically \(\sin(\pi - x)\)
  • Knowledge of substitution methods in calculus, particularly u-substitution
  • Basic skills in manipulating algebraic expressions and integrals
  • Study the properties of definite integrals and their transformations
  • Learn more about trigonometric identities and their applications in calculus
  • Practice u-substitution techniques with various integral problems
  • Explore advanced integral calculus topics, such as integration by parts and reduction formulas
Students and educators in calculus, particularly those focusing on integral calculus and trigonometric identities. This discussion is beneficial for anyone looking to deepen their understanding of integral transformations and proof techniques.
Samuelb88
help with u-substitution - prove...
Some function f is continuous on [0,Pi]
Prove: [tex]\int_0^{\pi}\\xf(sin x)\,dx = \frac{\pi}{2}\right)\int_0^{\pi}\\f(sinx)dx[/tex]
using the substitution [tex]u=\pi-x[/tex].
Identities, integral properties.
I've tried this two ways, (1) trying to transform the integral on the left ([tex]\int_0^{\pi}\\xf(sin x)\,dx[/tex]) to the one on the right and (2) vice versa.
1) If I am to use the u-sub: [tex]u=\Pi-x[/tex], then:
[tex]du=d(\Pi-x)=-dx[/tex] <==> [tex]-du=dx[/tex]
First, from the identity:
[tex]sin(\Pi-x)=sinx[/tex]
I re-expressed the integral like such:
[tex]\int_0^{\pi}\\(\Pi-x)f(sin(\Pi-x))\,dx[/tex]
Then substituted the quantity u into the integrand:
[tex]-\int_\Pi^{0}\\(u)f(sin(u))\,du[/tex]
Therefore:
[tex]\int_0^{\Pi}\\(u)f(sin(u))\,du[/tex]
Now here's where I get stuck, after much trial and error, ultimately leading to no where, I've found that [tex]\frac{d}{dx}\right)(\frac{F(x^2)}{2}\right)) = xf(x^2)[/tex].
2) From the left side of the statement.
[tex]\frac{\pi}{2}\right)\int_0^{\pi}\\f(sinx)dx[/tex]
When I start from the side, it appears as though the quantity [tex]u = \frac{2}{\Pi}\right)x[/tex] and the differential [tex]du=\frac{2}{\Pi}\right)dx[/tex] but then obviously I can't set u=Pi-x.
Therefore:
I'm not sure what you are doing here. This has taken you right back where you started.
If [itex]u = \pi - x[/itex] then [itex]du = -dx[/itex] as you indicated, so
[tex]\int_0^\pi x f(\sin x) dx = \int_0^\pi (\pi - u) f(\sin(\pi - u)) du =<br /> \int_0^\pi (\pi - u) f(\sin u) du[/tex]
Note that there's nothing special about the letter [itex]u[/itex] on the right hand side. You can just as well replace it with [itex]x[/itex]. If you do that, the answer is actually right in front of your eyes, in a slightly tricky form.
  • · Replies 105 ·
13K
