Physics Kinimatics/Energy Question
  • Thread starter Thread starter davidkis
    Physics
The discussion focuses on calculating the increase in minimum braking distance when a car's speed is increased by 40%. The relevant equations include kinetic energy (K=1/2 m v^2) and work (w=fd). The solution involves setting up a ratio based on the relationship between velocity and braking distance, leading to the conclusion that the braking distance increases by a factor of approximately 1.96 when speed is increased by 40%. This is derived from the equation D = V^2 / (2MG), where the new velocity is 1.4 times the initial velocity.
  • Understanding of kinetic energy and work-energy principles
  • Familiarity with basic algebra and ratio calculations
  • Knowledge of the relationship between speed, force, and distance
  • Ability to manipulate equations involving variables
  • Study the derivation of the work-energy principle in physics
  • Learn about the effects of friction on braking distance
  • Explore the concept of ratios in physics problems
  • Investigate the implications of speed changes on vehicle dynamics
Students studying physics, particularly those focusing on kinematics and energy concepts, as well as educators looking for practical examples of applying physics equations in real-world scenarios.
davidkis
If the speed of a car is increased by 40%, by what factor will its minimum braking distance be increased, assuming all else is the same? Ignore the driver's reaction time.
K=1/2 m v^2
w=fd
well i set kenitic energy to work so i got 1/2mv^2 = Fd, the force acting on the car is friction i then rewrote equation to V^2 / (2MG) = D, i got about 1.4 when i set velocity mass and gravity to 1. Didnt show up correctly on my webassign any suggestions?
I would suggest that since you don't know velocity or mass initially that you don't arbitrarily assign them to values. However, what you DO know is by what factor it was increased from the initial value. Which means you can set up a ratio given that you know it takes distance D to stop for velocity V, you then set up your equation with your new velocity (1.4*V) and find the scaling factor in front of D. Those other values should all cancel out if you take it as a ratio.
Hope this helps.
  • · Replies 17 ·
  • · Replies 37 ·
11K
  • · Replies 23 ·
