Solving a Uniform Beam Supporting Problem
  • Thread starter Thread starter HoneyPi
    Beam Uniform
The problem involves a uniform beam supported by a string and a hinge, requiring analysis of forces and torques to find the tension in the string. The context includes concepts from static equilibrium and trigonometry.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to derive an expression for tension based on equilibrium conditions and torque analysis. Some participants question the validity of trigonometric relationships used in the derivation, particularly regarding the sine and cosine functions of angles related to the beam and string.
Participants are actively engaging with the problem, offering suggestions for clarifying trigonometric relationships and exploring different approaches to eliminate variables. There is acknowledgment of a proposed solution, but the discussion remains focused on understanding the derivation process.
Participants note potential misunderstandings in trigonometric identities and relationships, indicating a need for careful consideration of angles and their corresponding sine and cosine values in the context of the problem setup.
HoneyPi
A uniform beam AB, of lenth l and mass m, is free in turn in a vertical plane about a smooth hinge at A. It is supported in a static position by a light string, of the same length l, attached to the end of end B of the beam and to an anchoring point C at a height h vertically above A.
  • Draw a diagram showing clearly all the external forces acting on the beam.
  • By considering the equilibrium conditions for the beam, find an expression for the tension in the string in terms of m, l, h and g, the magnitude of the acceleration due to gravity.
[tex] \textbf{R} = R_j \textbf{j} + R_k \textbf{k} [/tex]
[tex] \textbf{W} = -mg \textbf{k} [/tex]
[tex] \textbf{T} = - \textsl{T} \cos\theta \textbf{j} + \textsl{T} \sin\theta \textbf{k} [/tex]
[tex] \textbf{r}_R = \textbf{0} [/tex]
[tex] \textbf{r}_W = \frac{1}{2} l \cos(\frac{1}{2} \theta) \textbf{j} [/tex]
[tex] \textbf{r}_T = l \cos(\frac{1}{2} \theta) \textbf{j}[/tex]
(i)
(ii) Determining the torques:
[tex] \boldsymbol{\Gamma}_R = \textbf{0} [/tex]
[tex] \boldsymbol{\Gamma}_W = \frac{1}{2} l \cos(\frac{1}{2} \theta) \textbf{j} \times -mg \textbf{k} = - \frac{1}{2} l m g \cos(\frac{1}{2} \theta) \textbf{i} [/tex]
[tex] \boldsymbol{\Gamma}_T = l \cos(\frac{1}{2} \theta) \textbf{j} \times \textsl{T} \sin\theta \textbf{k} = l \textsl{T} \cos(\frac{1}{2} \theta) \sin\theta \textbf{i}[/tex]
Then since we consider the equilibrium conditions, we have
[tex] \boldsymbol{\Gamma}_T + \boldsymbol{\Gamma}_W + \boldsymbol{\Gamma}_R = \textbf{0}[/tex]
Solving this in i-direction gives:
[tex] l \textsl{T} \cos(\frac{1}{2} \theta) \sin\theta = \frac{1}{2} l m g \cos(\frac{1}{2} \theta)<br /> \Rightarrow \textsl{T} \sin\theta = \frac{1}{2} m g [/tex]
And now I am not sure about the following:
Since
[tex]\sin(\frac{1}{2} \theta) = \frac{\frac{1}{2} h }{l}[/tex]
it follows that
[tex]2 \sin(\frac{1}{2} \theta) = \sin\theta = \frac{h}{l}[/tex]
And so
[tex] \textsl{T} \frac{h}{l} = \frac{1}{2} m g \qquad \Rightarrow \quad \textsl{T} = \frac{mgl}{2h} [/tex]
I'd appreciate it if someone could help me out with the last part of (ii) and also checking whether I did the other parts correctly.
Thanks a lot :)
Honey [tex]\pi[/tex]
Hi Honey π, welcome to PF.
In the last part 2sin(θ/2) is not equal to sinθ.
You know that sin(θ/2) = (h/2l).
Using trig. can you find cos(θ/2)
Then sinθ = 2sin(θ/2)cos(θ/2)
Let a be the altitude, then [tex]\cos(\frac{\theta}{2}) = \frac{a}{l}[/tex], but how can I eliminate the variable "a"?
I forgot to metion that I have the answer but no approach. The tutor's solution say that the answer is [tex]T=\frac{mgl}{2h}[/tex].
Thanks
Consider the angle between rod and string as θ1 and the angle between rod and the vertical as θ2.
Take the component of mg along the rod and perpendicular to the rod.
Take the components of T along the rod and perpendicular to the rod.
Perpendicular components constitute torque.
In triangle ABC, according to the properties of triangle,
h/sinθ1 = l/sinθ2. Noe try to solve the problem.
  • · Replies 24 ·
