Thread Closed
Does my proof make sense?
Share Thread Thread Tools
Oct9-09, 09:07 PM   #1
Prove that for any polynomial function f, and any number a, there is a polynomial function g, and a number b, such that f(x) = (x-a)g(x) + b for all x.
2. Relevant equations
3. The attempt at a solution
Base Case: Let f(x) be a polynomial of degree n = 1. Then:
[tex]
\begin{align*}
f(x) &= c_1x+c_0\\
f(x) &= c_1x - c_1a + c_1a + c_0\\
f(x) &= (x-a)c_1 + c_1a + c_0\\
f(x) &= (x-a)g(x) + b
\end{align*}
[/tex]
where g(x) = c1 and b = (c1a + c0).
Let P(n) be the statement that every polynomial function of degree n can be written as f(x) = (x-a)g(x) + b.
Take P(n+1) and assume P(n) is true:
[tex]
\begin{align*}
f(x) &= c_{n+1}x^{n+1} + c_{n}x^{n}+...+c_1x + c_0\\
f(x) &= c_{n+1}x^{n+1} + (x-a)q(x) + k_0\\
f(x) &= c_{n+1}x^{n+1} - c_{n+1}x^na + c_{n+1}x^na + (x-a)q(x) + k_0\\
f(x) &= (x-a)(c_{n+1}x^n) + c_{n+1}x^na + (x-a)q(x) + k_0\\
f(x) &= (x-a)(c_{n+1}x^n) + (x-a)r(x) + k_1 + (x-a)q(x) + k_0\\
f(x) &= (x-a)(c_{n+1}x^n + r(x) + q(x)) + k_1 + k_0\\
\end{align*}
[/tex]
where g(x) = cn+1xn + r(x) + q(x)
and b = k1 + k0.
I think it's right, but I'm always so unsure of myself when it comes to induction.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Oct9-09, 10:15 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
That seems ok to me. It might help a bit if you explicitly say why you can make certain substitutions because of the induction hypothesis. But I think it's basically ok. And as a technical point you can't just prove P(n+1) from P(n). c_n might be 0. P(n) should really be "every polynomial function of degree k<=n can be written as f(x) = (x-a)g(x) + b". But that's really just a legal fine point.
Oct9-09, 11:34 PM   #3
thanks very much.
Dec22-09, 01:40 AM   #4
Hi,
could someone explain how we go from 1. to 2. in the expressions below?
I fail to see how [tex]c_{n+1}x^na=(x-a)r(x)+k_1[/tex]
Thanks.
[tex]
\begin{align*}
1.f(x) &= (x-a)(c_{n+1}x^n) + c_{n+1}x^na + (x-a)q(x) + k_0\\
2.f(x) &= (x-a)(c_{n+1}x^n) + (x-a)r(x) + k_1 + (x-a)q(x) + k_0\\
\end{align*}
[/tex]
Dec22-09, 02:14 AM   #5
Recognitions:
It's the induction hypothesis. You assume every polynomial of degree <=n can be written as (x-a)*r(x)+k. Think about it. The OP didn't state this as clearly as should have been done. See if you can do better. Look at the n=1 case. If you understand that, you understand everything. Also think about posting your own threads.
Dec22-09, 03:24 AM   #6
Quote by Dick View Post
Since we show that [tex]f(x)[/tex] can be written as [tex](x-a)g(x)+b[/tex] for the [tex]n=1[/tex] case, we can assume that it holds for [tex]k \leq n[/tex], just as you wrote in an earlier post. Then we check to see if the statement holds for the [tex]n+1[/tex] case. I understand that (to the extent I can understand anything).
[tex]f(x)=c_1x+c_0[/tex]
if [tex](x-a)[/tex] is a factor of [tex]f(x)[/tex] then [tex]f(a)=0[/tex].
[tex]f(\frac{-c_0}{c_1})=c_1(-\frac{c_o}{c_1})+c_0 =0 [/tex]
The Remainder Theorem gives that:
[tex]f(a)=b[/tex], so
[tex]f(x)=(x-(-\frac{c_o}{c_1}))c_1+c_1(-\frac{c_o}{c_1})+c_0[/tex]
I guess this is all good and well if [tex](x-a)[/tex] is a factor of [tex]f(x)[/tex]. But if it isn't then,
[tex]f(x)=(x-a)c_1 + c_1(a)+c_0[/tex]
I've successfully managed to confuse myself.
As for making my own threads, I always read how one should do a proper search before posting. I thought it would be better not to make my own thread about something that has been covered in the past. Will do so in the future though, thanks.
Dec22-09, 09:13 AM   #7
Recognitions:
n=1. f(x)=c1*x+c0=c1*x-c1*a+c1*a+c0=c1*(x-a)+(c1*a+c0). c1*a+c0 is a number. c1 is a 'polynomial' of degree less than 1. Now lets do n=2. f(x)=c2*x^2+c1*x+c0=c2*x^2-c2*x*a+c2*x*a+c1*x+c0=c2*x*(x-a)+(c2*x*a+c1*x+c0). Since (c2*x*a+c1*x+c0) is a polynomial of degree one, by the induction hypothesis (and as we showed above) it can be written as p(x)(x-a)+b where p(x) has degree <1 (e.g. it's really just a constant). So f(x)=c2*x*(x-a)+p(x)(x-a)+b=(c2*x+p(x))*(x-a)+b. So f(x)=q(x)*(x-a)+b where q(x)=c2*x+p(x) has degree 1. Try doing n=3 explicitly.
Yep, researching is a great idea. In preparation for solving the problem or posting your own thread. I don't necessarily even pay much attention to add ons to ancient posts unless there are my own. If I see some other post with 5+ replies to it, I'll figure the problem is already being dealt with and move on. You'll get more replies faster if it's a new thread.
Dec22-09, 11:16 PM   #8
Hi,
Here's my try at the n=3 case:
[tex]
\begin{tabular}{ r c l }
\(f(x)\) & \(=\) & c_3x^3+c_2x^2+c_1x+c_0\) \\
& \(=\) & c_3x^3-c_3x^2a+c_3x^2a+c_2x^2+c_1x+c_0\) \\
& \(=\) & (x-a)c_3x^2+c_3x^2a+c_2x^2+c_1x+c_0\)
\end{tabular}
[/tex]
[tex]c_3x^2a+c_2x^2+c_1x+c_0[/tex] is a polynomial of degree two, and can, by the induction hypothesis be written as [tex](x-a)p(x)+b[/tex].
[tex]
\(f(x)\) & \(=\) & (x-a)c_3x^2+(x-a)p(x)+b\) \\
& \(=\) & (x-a)\left(c_3x^2+p(x)\right)+b\) \\
\end{tabular}
[/tex]
[tex]q(x)=c_3x^2+p(x)[/tex] has degree 2, and [tex]b[/tex] has degree 1.
Thank you for being patient!
Dec23-09, 09:17 AM   #9
Recognitions:
That's nice. It was worth waiting for.
Dec23-09, 10:50 PM   #10
You are too kind, thanks. I feel comfortable with this now.
Thread Closed
Thread Tools
Similar Threads for: Does my proof make sense?
Thread Forum Replies
Does this make sense? Set Theory, Logic, Probability, Statistics 17
does this make any sense? Special & General Relativity 2
Does this make any sense? General Physics 1
Um, how does this make sense? General Physics 4
Trying to make Web services make sense Computing & Technology 0
