How can I make a manual hydraulic log splitter using a lever?
The discussion centers around the construction of a manual hydraulic log splitter, focusing on the principles of hydraulics, the mechanics of levers, and the necessary components for such a project. Participants express varying levels of understanding of hydraulic systems and seek guidance on how to implement their ideas.
  • Homework-related
  • One participant expresses a lack of knowledge about hydraulic principles and requests a complete tutorial for manual hydraulic machines.
  • Another participant provides calculations related to force and area in hydraulic systems, illustrating how pressure works using piston diameters and force applied.
  • A participant mentions the need to understand how to change the direction of motion in a hydraulic system when pulling a lever.
  • There is a request for information on components such as hydraulic rams, pumps, and flow diverters relevant to building a log splitter.
Participants do not appear to reach a consensus on the specifics of hydraulic principles or the construction of the log splitter, indicating that multiple competing views and uncertainties remain in the discussion.
Limitations include a lack of detailed understanding of hydraulic systems among some participants, as well as unresolved questions about the mechanics of lever operation and component selection.
Individuals interested in DIY projects involving hydraulics, those seeking to understand the mechanics of log splitting, and learners exploring the principles of fluid mechanics may find this discussion beneficial.
anonymoussome
We are thinking of making a project on Hydraulic manual log splitter.
But the problem is we don't know much about hydraulic principles and stuff...
could somebody provide me with the link of complete tutorial for manual hydraulic machines.
We wish to make it hand or foot operated using lever...but how to do that we have many doubts.
Help!
I hope you are tying to split small logs. My purchased log splitter uses upwards of 20 tons of force to split logs.
Anyways, you can just look at simple force vs area calculations.
For example,
Pressure = force/area
Say you have a 3 inch diameter piston and you are planning to move a 3 inch diameter piston by providing force on the 1 inch diameter piston.
The area of the 1 inch piston is simply (1^2*(3.141592))/4 = 0.7854 square inches.
In a similar fashion the 3 inch piston is 7.0686 square inches.
Now with a force on the 1 inch piston of 10 lbs will create a pressure of 12.73 psi.
Using a simple ratio of pressure on the 1 inch piston to the 3 inch piston the resulting force on the 3 inch pistion is 90 lbs. That is 9 times higher then the initial force of 10 lbs on the 1 inch piston.
Another example, is a car jack. You provide a small force on the small piston and the larger piston provides a large force that easily lifts the car upwards.
Hope that helps.
Thanks
Matt
I know the Pascal law...I want to know how hydraulics work and how to change the direction of motion
Like I am pulling the lever and the piston is moving forward. How to realize that?
So you are looking for information on the hydaulic ram, pump, flow diverter flow, and other log splitter components?
Thanks
Matt
yes sir I am looking for this info.
11K
  • Sticky
  • · Replies 0 ·
