Proving the limit (epsilon delta) #3
The discussion revolves around proving a limit using the epsilon-delta definition, specifically the limit as x approaches 8 for the function sqrt(x + 1) equating to 3. Participants are exploring the formal requirements of the proof and the necessary conditions for the chosen delta.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the original poster's approach of working backwards from the desired conclusion and question the validity of the steps taken. There are inquiries about ensuring positivity in the inequalities used and clarifications on the correct expressions for the limit translation.
The conversation is ongoing, with participants providing feedback on the original poster's reasoning and suggesting that further validation of the chosen delta is necessary. There is an emphasis on ensuring that the steps taken in the proof are logically sound and that all assumptions are checked.
Participants note the importance of confirming the positivity of terms involved in the inequalities and the potential errors in translating the limit into the epsilon-delta framework. There is a focus on the arithmetic properties relevant to the proof.
zeion
Prove the following states directly using the formal e, d definition
[tex] \lim_{x\rightarrow 8} \sqrt{x + 1} = 3[/tex]
If 0 < |x-8| < d
Then 0 < sqrt((x+1) - 3) < e
Let e be given
3 < sqrt(x+1) < e + 3
9 < x + 1 < e2 + 6e + 9
0 < x - 8 < e2 + 6e
This suggests we choose d = e2 + 6e
I assume you want comments on your work? I have three, of varying degrees of importance.
1. The work you've done here is "working backwards" -- you've started with what you wanted to happen, and worked backwards to try and find something that would ensure it.
Now, what you want to do is to show that this choice of d really does do what you want it to do.
2. When you did this step:
did you remember to make sure everything was positive? A relevant law of arithmetic is
If 0 < a < b then a² < b²​
3. Your translation from limit to e-d has an error.
Does this mean I need to show that sqrt(x+1) and e + 3 are positive?
Are you talking about the sqrt((x+1) - 3)? It should be sqrt(x+1) + 3?
And 3. (But notice that if you can show 3 is positive, then it's very easy to show the other two are positive)
It's obvious enough in this case that you don't need to bother mentioning it in your work -- but I want to make sure that you know what you're doing when you apply steps like this.
"sqrt(x+1) - 3", actually.
Yes I meant that sorry.
So now I need to show that
if 0 < x - 8 < e^2 + 6e
then 0 < sqrt((x+1) - 3) < e
is true?
is true?
(did you mean "|x-8|"?)
If you are still interested in finishing the e-d problem you originally wrote down, then yes that is what you need to do.
Sometimes it's possible to argue that all of your scratch work is reversible -- but it's probably not worth trying to do so until you become very comfortable with doing these arithmetic proofs involving inequalities.
  • · Replies 31 ·
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 22 ·
