| Thread Closed |
applied force on two blocks on a horizontal frictional plane |
Share Thread | Thread Tools |
| Oct13-09, 09:57 AM | #1 |
Two blocks connected by a string are pulled across a rough horizontal surface by a force applied to one of the blocks. The acceleration of gravity is 9.8 m/s2 . 1st block = 2 kg 2nd block = 8 kg Force on second block at 52◦ μ = 0.29 [ 2kg ]-------[ 8kg ]/ 52 degrees If each block has an acceleration of 1.6 m/s2 to the right, what is the magnitude of the applied force? Answer in units of N. 2. Relevant equations 3. The attempt at a solution What I got was 72.15 N but I got it wrong and I have no idea what I did wrong |
| Oct13-09, 10:07 AM | #2 |
Draw a fbd and sum the forces for each block in the x and y.
| Oct13-09, 02:36 PM | #3 |
| Oct13-09, 02:48 PM | #4 |
You need to find an expression for the normal force. In the y direction the force of gravity acts downward, the normal force acts upward, and the applied force acts upward.
| Oct13-09, 05:08 PM | #5 |
ok for the 8kg block i got 39.30N the problem that i am having for the 2kg block is that i do not no what Force I am solving for that is pulling the block is it Fcos60 like the previous one or is it the tension of the string
| Oct13-09, 06:29 PM | #6 |
The tension in the string is pulling the second block.
| Oct13-09, 07:06 PM | #7 |
would you find that simply by multiplying mass times acceleration of the 2kg block?
| Thread Closed |
| Thread Tools | |
Similar Threads for: applied force on two blocks on a horizontal frictional plane
| Coefficient of Friction when applied force is not horizontal to surface? | Introductory Physics Homework | 3 | ||
| two blocks connected by string with an angled force applied | Introductory Physics Homework | 2 | ||
| Normal force on horizontal plane | Introductory Physics Homework | 2 | ||
| Maximum applied force without blocks slipping | Introductory Physics Homework | 0 | ||
| Two blocks touching with one applied force...how to calculate force of one on another | Introductory Physics Homework | 3 | ||
