How Do You Calculate the Takeoff Speed in a Long Jump Problem?
The discussion revolves around calculating the takeoff speed of a long jumper who leaves the ground at an angle of 23 degrees and covers a horizontal distance of 8.7 meters before landing. The problem falls under the subject area of projectile motion in physics.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss resolving the takeoff velocity into horizontal and vertical components and forming simultaneous equations. There are attempts to relate time of flight and range to the problem, as well as questions about which kinematics equations to apply given the presence of two unknowns.
Some participants have provided guidance on breaking down the problem into components and suggested finding expressions for time of flight and range. However, there is still uncertainty regarding the application of kinematics equations and how to proceed from the established relationships.
Participants note the challenge of having two unknowns in the equations, which complicates the problem-solving process. There is also mention of a specific answer being known, which may influence the direction of the discussion.
Lil'Physicist
A long jumper leaves the ground at an angle of 23 degrees and travels through the air for a horizontal distance of 8.7m before landing. What is the takeoff speed of the jumper?
Trigonometric functions
Recently started physics and am going over stuff from the last two tests. Got stuck on this one and needed some help.
None of the three standard kinematics equations allows me to solve this (I end up having two unknowns for any equation I choose), and trigging out the velocity in the beginning leaves me with a triangle that only has angle measures. How can I start on this problem?
Denoting the takeoff velocity as v, resolve it into the horizontal and vertical components. You will be able to get an expression each for the horizontal and vertical components, which form a pair of simultaneous equations.
Hi Lil'Physicist. welcome to PF. It is a vey common problem in projectile motion. Open any reference book or visit Hyper Physics site and go through the projectile motion.
Try to find out two expression. (1) time of flight and (2) range of the projectile.
Then try to solve the problem.
I ended up with sin 23=v(y-axis)/v for the y-axis velocity and cos 23=v(x-axis)/v for the x-axis velocity. I do not understand which kinematics equation to substitute this into because of the two unknown variables.
If someone could show the first few steps of the problem, I need that to get the ball rolling. The correct answer is 11 m/s... now just to figure out how that is so...
Using trig functions, you can find the maximum height the jumper will go...
tan23=(height of jump)/8.7
Now you have height of jump, you can find the time it takes to complete the jump. Once you have time, you have horizontal distance, time and then solve for Vi via equation:
Xf = Vicos(23) * (time) where Xf is the horizontal distance of the jump and Vi is the initial velocity of the jumper
17K
  • · Replies 26 ·
