Relating inverse metric to densitized triads
  • Context: Graduate
  • Thread starter Thread starter jziprick
    Inverse Metric
The discussion focuses on deriving the inverse metric \( q^{AB} \) in terms of the densitized triad \( E^A_a \) within the context of Loop Quantum Gravity. The induced Riemannian metric is defined as \( q_{AB} = e^a_A e^b_B \delta_{ab} \). The solution reveals that \( E^A_a = \sqrt{\text{det}(q)} e^A_a \), leading to the relationship \( E^A_a E^B_b \delta^{ab} = \text{det}(q) q^{AB} \). This establishes a clear connection between the densitized triad and the inverse metric.
  • Understanding of Loop Quantum Gravity concepts
  • Familiarity with Riemannian geometry and metrics
  • Knowledge of tensor notation and indices
  • Basic grasp of determinants in linear algebra
  • Research the properties of densitized triads in Loop Quantum Gravity
  • Study the derivation of inverse metrics in Riemannian geometry
  • Explore the implications of the determinant of a metric tensor
  • Learn about the role of triads in quantum gravity theories
Researchers and students in theoretical physics, particularly those focusing on quantum gravity, as well as mathematicians interested in Riemannian geometry and its applications in modern physics.
jziprick
Reading through an introductory Loop Quantum Gravity paper, I am given an induced Riemannian (space) metric:
\begin{equation}
\end{equation}
where $A = 1,2,3$ are covariant indices and $a = 1,2,3$ are internal indices of the triads $e^a_A$. The densitized triad is defined to be:
\begin{equation}
E^A_a := \frac{1}{2} \epsilon^{ABC}_{abc} e^b_B e^c_C.
\end{equation}
How do I determine the inverse metric $q^{AB}$ in terms of $E^A_a$? Must I guess the form and require that:
\begin{equation}
q^{AB}q_{BC} = \delta^A_C \ \ ?
\end{equation}
Sorry about messing up the teX. Here it is again:
[tex] q_{AB} = e^a_A e^b_B \delta_{ab}[/tex]
where [tex]A = 1,2,3[/tex] are covariant indices and [tex]a = 1,2,3[/tex] are internal indices of the triads [tex]e^a_A[/tex]. The densitized triad is defined to be:
[tex] E^A_a := \frac{1}{2} \epsilon^{ABC}_{abc} e^b_B e^c_C.[/tex]
How do I determine the inverse metric [tex]q^{AB}[/tex] in terms of [tex]E^A_a[/tex]? Must I guess the form and require that:
[tex] q^{AB}q_{BC} = \delta^A_C \ \ ?[/tex]
I figured it out, so I should post the solution. It becomes simple once you show that:
[tex] E^A_a = \sqrt{det(q)}e^A_a[/tex]
where [tex]e^A_a[/tex] is the inverse of [tex]e^a_A[/tex]. Then clearly we have:
[tex] E^A_aE^B_b \delta^{ab} = det(q) q^{AB}[/tex]
using the definition given in the original post for [tex]q_{AB}[/tex].
