Particle Motion with Constant Acceleration
The problem involves a particle moving in the xy plane with constant acceleration. The initial position and velocity of the particle are provided, along with its position and velocity after a time interval. Participants are tasked with finding the initial velocity, acceleration, and expressions for velocity and position as functions of time.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to use the average velocity formula but encounters difficulties with the calculations. Some participants suggest using kinematic equations to relate the variables involved.
  • Questions arise regarding the implications of constant acceleration on the changing velocity of the particle.
  • One participant questions the coherence of the problem description, leading to a discussion about the nature of constant acceleration and its effects on velocity.
Participants are actively engaging with the problem, with some providing guidance on using kinematic equations. There is an acknowledgment of confusion regarding the problem setup, but some participants appear to be making progress in understanding the relationships between the variables.
There is a noted confusion regarding the interpretation of constant acceleration and its implications for velocity changes. The original poster expresses a need for guidance on multiple parts of the problem.
Loppyfoot
A particle moves in the xy plane with constant acceleration. At t = 0 the particle is at rvec1 = (3.7 m)i + (3.4 m)j, with velocity vvec1. At t = 3 s, the particle has moved to rvec2 = (9 m)i − (1.9 m)j and its velocity has changed to vvec2 = (5.4 m/s)i − (6.5 m/s)j. (a) Find vvec1.(b) What is the acceleration of the particle?(c) What is the velocity of the particle as a function of time?(d) What is the position vector of the particle as a function of time?
I need some guidance. I tried using the average velocity formula for (a), but it doesn't seem to be working for me. I tried doing 9-3.7 / 3. for the i vector. And likewise, for the j vector (-1.9-3.4)/3. I get 1.76i-1.76j, and it isn't correct.
I need some guidance on the others too. Thanks guys.
Jeez, I cannot seem to get this! I have been trying to get it all night.
Hi Loppyfoot! :smile:
(use bold for vectors :wink:)
Loppyfoot said:
… I tried using the average velocity formula for (a), but it doesn't seem to be working for me.
Distance velocity and acceleration are all vectors, and so they add like vectors.
Try s = vt + (1/2)at2 :wink:
How should I implement that equation into part a), if I do not know the acceleration vectors yet?
Part of your problem description doesn't make sense to me.
Edit: Now it does make sense.
Edit: Ignore the following.
This description says that the particle moves with constant acceleration. Later it says that the velocity has changed to ... If the acceleration is constant, the velocity can't change, since acceleration is the instantaneous rate of change of velocity with respect to time.
If the acceleration is constant, doesn't that mean that the velocity is changing at a constant rate?
Never mind. I take back what I said. I was thinking zero acceleration, not constant acceleration.
I think I figured it out. I applied one of the 4 kinematic equations, and then I should be able to get the rest from there.
EDIT: I got a and b, but how would I go about getting c and d?
For c, if you got b, use it to get the velocity. a = dv/dt, so you can integrate what you have for a to get v as a function of t. You'll get a constant (vector) of integration, but you know v(3), so should be able to figure out the constant.
For d, do essentially the same thing: v = ds/dt. Integrate that to get s and use the given information about s(0) to figure out this constant (vector) of integration. Does that make sense?
  • · Replies 38 ·
