| Thread Closed |
Bypass Ratio |
Share Thread | Thread Tools |
| Oct14-09, 10:18 AM | #1 |
Bypass Ratio
What Basis Bypass Ratio Has Chosen For Turbofan Engine
| Oct14-09, 12:55 PM | #2 |
Recognitions:
Bypass ratios range from very small in some applications to very large in others. What do you mean by basis?
| Oct14-09, 02:07 PM | #3 |
Recognitions:
It's all dictated by the cycle requirements. There is no quick way to nail it down.
| Oct15-09, 12:35 AM | #4 |
Bypass Ratio
if you see bypass ratio varies from 0.1:1>br<1:1 for turbojet engine and 5:1>br<11:1 for turbofan engine.
Some turbofan engine has bypass ratio CFM 56 2c1 has 6, and CFM 56-5b3/4 has 5.3 and 5.5 has Ge 90 has 8.4 and ge 90-115b has 9 and various ratio. when your check this the thrust range is also varies with bypass ratio. is bypass ratio chosen by thrust or any other parameter. |
| Dec14-09, 03:22 AM | #5 |
It's chose by flight regime of the engine's intended use. For most commercial applications, high bypass turbofans are more efficient, as the design parameter is simply sustained high sub-mach cruise, with sufficient thrust for one engine-out performance at max gross take-off weight.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Bypass Ratio
| Bypass flow in a pebble bed reactor | Nuclear Engineering | 2 | ||
| Common Source Aplifier - finding values of bypass capacitors | Electrical Engineering | 2 | ||
