Vertical Component of a ball rolling off table
The problem involves a ball rolling off a table with a specified horizontal velocity and a given time to fall to the ground. Participants are tasked with determining the vertical and horizontal components of the ball's velocity just before it impacts the floor, while considering the effects of gravity.
  • Mixed
  • Participants discuss the use of kinematic equations, particularly questioning the application of formulas for distance versus velocity. There is exploration of the independence of vertical and horizontal motion components.
Some participants have provided guidance on the correct approach to finding the vertical component of velocity, while others are clarifying the distinction between distance and velocity. The discussion reflects a mix of interpretations regarding the formulas needed for the calculations.
There is an ongoing consideration of initial conditions, such as the initial vertical velocity being assumed as zero, and the implications of horizontal motion being unaffected by vertical forces. Participants are also grappling with the transition between calculating distance and velocity.
Chuck Norris
A ball rolls off a table with a horizontal velocity of 5 m/s. If it takes 0.6 seconds for it to reach the floor what is the vertical component of the ball's velocity just before it hits the floor? (use g= 10 m/s^2)
The second part of the question is what is the horizontal componenet ofthe ball's velocity just before it hits the floor?
D vert: 1/2at^2
I'm not sure if this is correct:
Dvert = 1/2at^2
1/2(10m/s^2)(0.6s)^2
Dvert= 1.8m
For the second part, would I do the exact same thing but plug in different times to plot the different spots the ball would project at on the way down?
Thanks for your help.
Dvert = 1/2at^2
Dvert= 1.8m
You're supposed to find the velocity, not the distance fallen.
1] Your answer to A is in m, yet you are asked for m/s.
2] Seems to me the answers are pretty simple. The vertical component and horizontal component are completely independent of each other. It would seem to me that the horizontal component is trivial (almost a trick question) - it does not even need to be calculated.
So then am I using the wrong formula all together?
Yep. You're using a formula for distance, but you need the formula for velocity.
V = V0 + at
V= 5 m/s + (10m/s^2)(0.6s)
V= 5.6 m/s?
I'm sure this is the wrong formula also.
Chuck Norris said:
V = V0 + at
V= 5.6 m/s?
This is the right formula, but you are using the wrong initial velocity. (5 m/s is the horizontal component of the initial velocity, not the vertical.) Treat vertical motion separately from horizontal. (Also: Double check your arithmetic.)
V = Vo + at
V= 0 + (10 m/s^2)(0.6s)
V= 6 m/s
I'm assuming since there is not a initial velocity given in the problem that the initial velocity is assumed to be 0. Sorry for all the dumb questions, physics has just been rough for me so far. Thanks for all your help so far.
Chuck Norris said:
V = Vo + at
V= 6 m/s
Perfect. The vertical component is 6 m/s downward. (So they might want you to call it - 6 m/s.)
Awesome! Thank you so much. Now for the second part,
Would I use the formula d(horiziontal)=volt?
Now I'm confused because if I use that formula and plug in the initial velocity of 0 obviously I'm going to get an answer of 0.
What is the initial horizontal velocity of the ball? What forces are acting on the ball horizontally (i.e. acceleration)?
The intial horizontal velocity is 5 m/s when it rolls off the table.
So would it be:
d=volt
D= (5m/s)(0.6s)
d= 3m?
nevermind i see that I'm looking for velocity again yet i went back to answering in distance
Would I just use the same formula as I used with the vertical component but plug in the 5m/s as the initial velocity instead of 0?
Haha wait so is the answer just 5 m/s? Because horizontal velocity doesn't change?
You're overthinking it. What is the initial horizontal v? What force(s) are acting to change the horizontal v?
The initial horizontal velocity is 5 m/s correct? I don't believe any forces are acting to change it...
unless the initial horizontal velocity is just zero...since there are no forces changing it
Correct and correct.
So...
The answer is just 5 m/s.
maybe?
Right. The horizontal velocity component starts out at 5 m/s and stays at 5 m/s. Gravity only affects the vertical component.
  • · Replies 38 ·
  • · Replies 60 ·
  • · Replies 32 ·
