The direction of the electric field at point P is +x direction
The electric field at point P, located on the positive x-axis at a distance of 39.0 units from the origin, has a magnitude of 7.35 N/C and is directed in the +x direction. A particle with a charge of 2.60 C placed at point P experiences a force calculated using the formula F = qE, resulting in a force of 19.11 N in the +x direction. According to Newton's 3rd Law, the force exerted by the particle on the ring is equal in magnitude but opposite in direction to the force exerted by the ring on the particle.
  • Understanding of electric fields and forces
  • Familiarity with Coulomb's Law
  • Knowledge of Newton's 3rd Law
  • Basic concepts of charge and electric field interactions
  • Study the principles of electric fields generated by charged conductors
  • Learn about the application of Coulomb's Law in electrostatics
  • Explore the implications of Newton's 3rd Law in electric force interactions
  • Investigate the effects of varying charge distributions on electric fields
Students of physics, electrical engineers, and anyone interested in understanding electrostatic forces and electric field interactions.
imationrouter03
Thank you for viewing this,.. here's my question i hope u can help:
A ring-shaped conductor with a radius 2.30 has a total positive charge 0.125 uniformly distributed around it. The center of the ring is at the origin of coordinates O.
(a)The magnitude of the electric field at point P, which is on the positive x-axis at 39.0 is 7.35 N/C
(b)The direction of the electric field at point P is +x direction
here's the question:
A particle with a charge of 2.60 is placed at the point P described in part (a). What is the magnitude of the force exerted by the particle on the ring?
and also What is the direction of the force exerted by the particle on the ring?
Thank you for your time,.. any advice would be appreciated
The force on a point charge is equal to the product of the charge and the electric field at the point, i.e.:
[tex]\vec{F} = q\vec{E} = (2.60\ C)(7.35\ N/C\ \hat{i}) = 19.11\ N\ \hat{i} = 19.1\ N\ \hat{i}[/tex]
Not that [itex]\hat{i}[/itex] is the unit vector in the [itex]x[/itex] direction, and the last bit, where I want from 19.11 to 19.1 was to take care of significant digits.
And by Newton's 3rd Law, the force exerted by the particle on the ring is the same in magnitude but of opposite sign of what AKG computed.
  • · Replies 20 ·
