Find how fast the radius of a circle get smaller as its area gets smaller
The discussion focuses on calculating the rate at which the radius of a circle decreases as its area diminishes from 75π cm² at a rate of 2π cm²/s. The initial approach involved using the area formula A = r²π and resulted in an incorrect rate of change for the radius. The correct method, as clarified by a peer, involves differentiating the area with respect to time, leading to the conclusion that dr/dt = -1/sqrt(75). This method aligns with the established relationship between area and radius, confirming the correct answer.
  • Understanding of calculus, specifically differentiation
  • Familiarity with the formula for the area of a circle, A = πr²
  • Knowledge of related rates in physics and mathematics
  • Ability to solve equations involving square roots
  • Study the concept of related rates in calculus
  • Learn how to differentiate functions involving multiple variables
  • Explore the implications of the chain rule in calculus
  • Practice solving problems involving the area and circumference of circles
Students studying calculus, particularly those focusing on related rates, as well as educators looking to clarify concepts related to the geometry of circles and differentiation techniques.
Sennap
(Translated, sorry my English) Find how fast does the radius of a circle get smaller when its area is 75*pi cm^2 and it (the area) gets smaller at a rate of 2*pi cm^2/s?
Not really any given equations, but I used these:
A = r^2 * pi
s = v*t + s0 (If v is a constant)
t=A/Va (where t is the time when A=0)
From now on I'll call area, A = 75*pi cm^2 and the rate v_a = 2*pi cm^2/s.
I gave myself that the speed (v) was constant, that shouldn't really change the answer.
So s = dv/dt = v*t + s0
By using A = r^2 * pi we know that:
r^2 = A/pi
r = sqrt(A/pi) and since at t = 0 then A = 75*pi so
r = sqrt(75) at t = 0, let's call r from now on s.
Let's find the time until A = 0, and therefore s=0
t = A/v_a = 75*pi/(2*pi) = 37,5 sec
So in 37,5 sec the circle area will be zero with is radius. Therefore we can see that:
s = v*t + s0
0 = v*37,5 + sqrt(75)
-sqrt(75) = v*37,5
v = -sqrt(75)/37,5
v = -2*sqrt(75)/75
v = -2/sqrt(75)
So my final answer was v = -2/sqrt(75) (or v = -2/(5*sqrt(3))But according to my teacher the correct answer is v = -1/sqrt(75).--
Here's how my teacher did it:
We know that F(t) = pi * r(t)^2 and
(1) F'(t0) = 2*pi*r(t0)*r'(t0) = -2*pi
(2) F(t0) = pi*r(t)^2 = 75*pi
for a specific t0.
According to (2) we know that r(t0) = sqrt(75) = 5*sqrt(3) and according to (1) we get r'(t0) = -1/r(t0) = -1/sqrt(75)
He called my solution "a waste of time" although he said it should work too, but couldn't explain to me why I didn't get the same answer.
Where did I go wrong (or even better, where did he go wrong?)
The area of the circle is A(r) = pi r2. Assuming that both A and r are differentiable functions of t, and differentiating with respect to t, you get
dA/dt = 2pi r dr/dt
Solve this equation for dr/dt. That will give you dr/dt for any arbitrary t.
Now evaluate dr/dt at the time when A is 75 pi cm2 and when dA/dt is -2 pi cm2/sec. You will need to find the radius r for which the area A is 75 pi cm2 to do this.
Thank you for a quick reply!
dr/dt = 1/(2*pi*r) dA/dt and dA/dt = -2*pi so
dr/dt = -1/r
And like I showed before r = sqrt(75) so the final answer is indeed:
dr/dt = -1/sqrt(75)**SOLVED**
Thank you again. I understand your solution a lot better than my teacher's.
