Derivative of 2^x: How to Calculate
  • Context: High School
  • Thread starter Thread starter l33t_V
    Derivative
The discussion revolves around calculating the derivative of the function 2^x. Participants explore different methods and rules of calculus applicable to this problem, including comparisons to the power rule and the use of exponential functions.
  • Homework-related
  • One participant asks for the derivative of 2^x and how to compute it.
  • Another suggests expressing 2^x as e^{x ln(2)} to facilitate differentiation.
  • Some participants question why the derivative cannot be calculated using the power rule as applied to x^k.
  • It is noted that the power rule applies only when the base is the variable being differentiated and the exponent is constant.
  • A participant mentions that certain calculus problems, like f(x) = x^x, cannot be solved using standard rules.
  • Another participant introduces a more general formula for derivatives involving variable bases and exponents.
Participants express differing views on the applicability of the power rule to the function 2^x, indicating a lack of consensus on the best approach to take.
There are limitations in the discussion regarding the assumptions about the applicability of various calculus rules, as well as the conditions under which they can be used.
l33t_V
Hello all. I would like to know what is the derivative of 2^x and how it is done. Thank you
Here's a hint, start by expressing it as :
[tex]2^x = e^{x \ln(2)}[/tex]
I'll give it a try. But why can't it be solved as we do x^k ? Like k*x'*x^(k-1)
Because that's against the rules.
The rule is
[tex]\frac{d}{dx}(x^n) = n x^{n-1}[/tex]
The base has to be the variable being differentiated against. The exponent has to be constant with respect to the base.
Luckily, all is not lost. We have lots of rules in calculus. Instead, we can use this one.
[tex]\frac{d}{dx}(e^{f(x)}) = f'(x) e^{f(x)}[/tex]
This rule can only be used when the base is the Euler number e and when the exponent is a function of x. If we want to use this rule for your problem, we can do a little advanced algebra to change the base (which is what uart suggested).
Some problems in calculus can't be solved exactly, even if they look super simple. For example, if you have the function [tex]f(x) = x^x[/tex], you can use NEITHER rule.
Use the power rule.
[tex]\frac{d}{dx}u^v=v u^{v-1} \frac{du}{dx}+\log(u) u^v \frac{dv}{dx}[/tex]
Another thread about it.
