2nd order linear differential equation (homogeneous)
The discussion revolves around solving a second-order linear homogeneous differential equation with given initial conditions. The original poster attempts to find the solution but questions the correctness of their final answer.
  • Participants discuss the original poster's method of solving the differential equation, including the division by a constant and the identification of repeated roots. There are questions about rounding errors and the use of fractions in calculations.
The discussion is ongoing, with participants providing feedback on the original poster's calculations and suggesting that rounding may have affected the accuracy of the solution. Some participants have shared their own results, indicating a lack of consensus on the correctness of the original poster's answer.
There is mention of initial conditions and the possibility of using fractions instead of decimal approximations, which may influence the solution's accuracy. The original poster expresses uncertainty about where their solution went wrong.
jumbogala
Solve 354y`` −692y` + 235y =0
y(0) = 7
y`(0) = 4
First I divided the equation by 354 to get y`` - 1.56y` + 0.894y = 0.
Then I found the roots of this to be 0.94, repeated twice.
For repeated roots the solution looks like y= C1e0.94t + C2te0.94t
Using the initial conditions, solve. You find that C1 = 7.
y` = 0.94C1e0.94t + 0.94C2te0.94t + C2e0.94t. Plugging in t = 0 we find that C2 = -2.61.
Therefore y = y= 7e0.94t -2.61te0.94t
But this isn't the correct answer. Where did I go wrong?
You've rounded off incorrectly. -612/324 is 1.89 to two places, not 1.88. But I would be inclined to leave it as a fraction: 17/9. Are you allowed to do that?
Apart from the fact that you rounded nearly every single number, why isn't the solution correct?
Because I got the same (up to rounding errors).
Okay, I used fractions in my answer and that worked. Next time I'll be careful not to round carelessly... thanks!
  • · Replies 27 ·
  • · Replies 33 ·
