Solving Equations: How to Find the Solution for (4/3)x^3 + x^2 - 2x + 8/3 = 0
  • Thread starter Thread starter kd001
The discussion revolves around solving the cubic equation (4/3)x^3 + x^2 - 2x + 8/3 = 0. Participants explore methods for finding the roots of this polynomial, noting that traditional techniques like the quadratic formula are not applicable.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants suggest multiplying by a constant to simplify the leading term and discuss the rational roots theorem as a potential approach. There are mentions of Cardano's formula and the Newton-Raphson method for approximating roots.
Some participants have offered guidance on methods to explore, while others express uncertainty about their familiarity with the suggested techniques. Multiple approaches are being considered, but no consensus has been reached on a specific method to pursue.
The original poster indicates that this is a practice problem rather than a formal homework assignment, which may influence the depth of exploration and the methods discussed.
kd001
This isn't really homework. I've just been practicing some equations and I'm stuck at the one below.
The quadratic formula does not apply to this so how do I solve it for x?
Thanks
The first thing I would do is multiply both sides by 3/4 to get rid of the ugly leading term. Then try using the rational roots theorem. In short, if there is a rational root for your polynomial, then it is given by a factor of the coefficient of x0 over a factor of the coefficient of x3. This will hopefully give you a very short list to try. If none of those work, then the polynomial has no rational roots and you have to use more advanced methods. If it does work, you can use long division to get the rest of the roots, if any.
Thanks for the quick reply. I'll try that although its not something I'm familiar with.
For cubics, there is always Cardano's formula, but it is rather messy in that it can give complicated complex expressions for simple real roots. The rational root method is often faster and less time consuming.
Otherwise, as you are posting in the calculus forum, you can use Newton-Raphson to approximate a root if there are no rational roots.
  • · Replies 105 ·
13K
  • · Replies 16 ·
  • · Replies 27 ·
