Caculating velocity on a different points on a rim of a wheel
The problem involves a motorcycle accelerating from rest with a constant acceleration, focusing on the velocities and accelerations of points on the rim of its front wheel after a specified time. The subject area includes kinematics and rotational motion.
  • Mixed
  • Participants discuss the need to consider both linear and rotational velocities of the wheel. There are attempts to relate the velocities of points on the rim to the center of mass and questions about how to incorporate centripetal acceleration. Some participants explore the implications of not knowing the radius of the wheel and how that affects calculations.
The discussion is ongoing, with various approaches being considered. Some participants suggest leaving answers in terms of the radius, while others debate the relevance of angular acceleration and the need for radius to determine linear acceleration. There is recognition of the complexity introduced by the rotational motion and the need for clarity on how to calculate the accelerations of the specified points.
Participants note that the problem does not provide the radius of the wheel, leading to discussions about potential assumptions or average values that could be used in calculations. The context of the homework is a college physics course, with participants preparing for a colloquium.
mmoadi
Motorcycle is accelerating from the rest with a constant acceleration a = 2 m/s². We are observing its front wheel (see picture) after a time t = 10 s. This wheel is not slipping while accelerating. How much are velocities of points A, B, and C on rim of wheel? How much are the accelerations of these points?
v= v0 + at
A: v = v0 + at → v= -20 m/s
B: v= sqrt(vA² + vB²) → 28.3 m/s
C: v= v0 + at → v= 20 m/s
Hint: Find the velocity of the center of the wheel with respect to the ground, the velocity of the rim with respect to the center, then the velocity of each part of the rim with respect to the ground.
There is a rotational part that you seem to be neglecting, and when you include it, you may be quite surprised, especially about point C. Also, don't forget that the problem asks for the accelerations, too.
So, that means that I have to take into the consideration also centripetal acceleration?
If so, is equal to:
ac= 4πr / t²
v= 2πr / t
Because I don't have the r, I combined the above formulas together to get:
ac= 2πv / t
ac= 12.56 m/s²
Is this what you meant by "There is a rotational part that you seem to be neglecting"?
But how do I go on from here?
I did some research and this is what I found out:
1. A wheel rolling over a surface has both a linear and a rotational velocity.
2. The linear velocity of any point on the rim of the wheel is given by vcm= ωr.
3. Because when the wheel is in contact with the ground, its bottom part is at rest with respect to the ground, the wheel experiences a linear motion with a velocity equal to + vcm besides a rotational motion (picture).
4. Conclusion: the top of the wheel moves twice as fast as the center and the bottom of the wheel does not move at all.
The only problem now is: How to calculate r?
Please, help?
That's a good question. I'm sorry, I didn't notice that the problem doesn't give you the radius. I have no idea how to do it without knowing the radius (or a way to determine it, which I also don't see). Are you sure that the problem doesn't tell you the size of the wheel, or some other info that you're neglecting?
No, there is no mentioning of the quantity of r, except if knowing that we are talking about motorcycle, we just put an average size for the r of motorcycle tire? Can this option be possible?
Sure, in the "real world". However, in the "real world", if the solution were really important, you would still go and determine r. It just depends on what kind of a course this is.
College physics, I'm preparing for my first colloquium. I'm studying pharmacy in Slovenia.
Just leave the answer in terms of r.
I agree with turin. While you can easily find the speed of the points, without the radius I see no way to determine their accelerations.
I disagree.
You can find all those velocities in terms of the velocity of the center of mass. Taking that expression and differentiating it with respect to time should give you an answer solely in terms of the acceleration of the center of mass. Therefore, the radius of the wheel is irrelevant.
Differentiating the speed as a function of time will give you one component of the acceleration. What about the change in angle?
So, how can I write down the acceleration in terms of r for the three point A. B, and C?
Any hint?
I know that formula for tangential acceleration is a_t= rα.
Thank you.
I think that's irrelevant to this question. It asks about the mathematical points A, B and C. Those at the bottom, top and right side of the wheel.
What their acceleration is, in this case, is how their velocity changes with respect to time.
To know the change in angle over time would, of course, require we know the radius.
Velocity can change in magnitude or direction.
Precisely the point.
And again, that is irrelevant as you are asked for the linear acceleration, and not the angular acceleration.
The direction of the velocity does not change, since the acceleration of these points is always directed in the same direction as the velocity.
You even used that as a premise for solving for the velocities.
For rolling motion without sliding:
[tex]V_{CM}=\omega R[/tex]
[tex]a_{CM}=\alpha R[/tex]
With respect to the center of mass:
[tex]V_{tangential}=\omega R[/tex]
[tex]a_{tangential}=\alpha R[/tex]
Vector addition can help us find the velocities and accelerations with respect to the original frame of reference in which the wheel does not slide.
RoyalCat said:
... you are asked for the linear acceleration, and not the angular acceleration.
A changing angle leads to a linear (radial) acceleration. The angle and radius together provide the linear magnitude, which is why we either need to know the radius, or how to determine it.
RoyalCat said:
The direction of the velocity does not change, ...
This is incorrect. The essence of rotation is a contantly changing direction.
The question asks for the acceleration of the specified points.
Why would you think that? It's rolling!
No I didn't.
No I didn't.
You assumed that the velocity of the top-most point is pointing in the direction of velocity of the center of mass. The acceleration would therefore have to be in the direction of the movement, otherwise you would have no way to tell the direction of the velocity.
Oh! I get it now! You need the radius to find the radial acceleration, which you would then sum up with the known tangential acceleration to find the acceleration of the specified points.
Heh, the magic of italics made it click for me.
Is that what you meant, or do I still not understand?
The direction of motion and the direction of acceleration are completely independent (instantaneously). For example, an object can accelerate downward from rest, and the motion of the rest state has no direction. Another example, a projectile shot up at an angle travels in a direction that is tangent to a parabola, but the acceleration is always vertically downward.
The point is that, the very top of the wheel has an instantaneous velocity that is in the same direction as the entire wheel, and this is actually just an assumption resulting from the assumed constraint on the shape and nonslippage of the wheel. There is indeed a component of the acceleration in this same direction, since the wheel is accelerating forward. This component of acclereation is itself composed from the linear acceleration of the wheel as a whole and the tangential acceleration of the point, and these two components must be equal by the same constraint that I mentioned earlier. However, there is a third component, the radial (centripetal) component, which cannot be determined until the radius is determined. Unlike the other two components, this third radial component grows in magnitude as the wheel speeds up.
As turin already explained, the only assumption needed to find the velocities was that of rolling without slipping. Your statement about acceleration doesn't follow.
Yes, you need the radial and tangential accelerations plus the acceleration of the center of mass to find the total acceleration of each point. And the radial acceleration depends on the radius.
  • · Replies 65 ·
