How Long Will It Take for a Balloon's Pressure to Equalize Through a Small Hole?
  • Thread starter Thread starter reno
    Pressure
The discussion centers on calculating the time it takes for a balloon's internal pressure of 9.7 KPa to equalize with ambient pressure through a small hole of 0.25 mm². The user initially considered simplifying the problem by modeling the balloon as a hollow cylinder and calculated the force exerted by the air at 2.425 N, with an air expulsion speed of 127 m/s. The user sought confirmation on these calculations and inquired about the applicability of Bernoulli's equation, ultimately resolving the problem independently.
  • Understanding of fluid dynamics principles, particularly Bernoulli's equation
  • Knowledge of pressure concepts in gases
  • Familiarity with basic physics equations related to force and velocity
  • Ability to perform calculations involving area and pressure differentials
  • Study the application of Bernoulli's equation in real-world scenarios
  • Learn about the principles of gas laws and their impact on pressure changes
  • Explore the concept of flow rate through orifices and its calculations
  • Investigate the dynamics of compressible versus incompressible fluids
Students in physics or engineering fields, educators teaching fluid dynamics, and anyone interested in practical applications of pressure and flow in gases.
reno
I have a balloon full of air, it is at a pressure relative to the ambient pressure of 9.7KPa and its volume is 3000cm3. The balloon is attached to a surface, this seal is airtight and perfect. The surface it is attached to contains a (very) small hole with an area of 0.25mm2. I am struggling to figure out how long it will take for the pressure within the balloon to equal that of the ambient pressure within the room.
This is what I am stuck on, I don't have a clue which equation to use.
I thought that I would start at simplifying almost everything, instead of imagining a balloon attached to a surface I could just imagine a hollow cylinder with a volume of 3000cm2 and the same pressure being synthesised by a force acting on top of the air seeing as though the pressure within the balloon doesn't change until the very last second which I can neglect. I though about imagining it like a syringe with a constant force.
I calculated that the force of the air after being forced through the hole will be 2.425N. I think that is right, I also figured out that the air would be expelled at 127m/s but this seems a little high, can someone confirm this?
I would very much like this to be almost totally my own work so if you could just give me a few gentle nudges or a couple a links to a web page I would be eternally grateful.
Can I use Bernoulli's equation? Or is that fluids only?
Never mind, solved it myself
  • · Replies 18 ·
22K
12K
