How Do You Derive the Torsional Pendulum Period Formula?
  • Thread starter Thread starter Melawrghk
    Pendulum Period
The discussion revolves around deriving the formula for the period of a torsional pendulum, specifically the expression T=2*pi*sqrt{(2IL)/(pi*r^{4}*G)}. The original poster presents their understanding of the relationship between torque, moment of inertia, and angular acceleration, and attempts to manipulate these equations to find an expression for angular frequency.
  • The original poster attempts to derive the period by relating torque and angular acceleration, leading to an expression for angular frequency. They express confusion over integrating their equation and the distinction between angular frequency and angular velocity.
Some participants provide feedback on the original poster's approach, suggesting that they have mixed up angular frequency and angular velocity. Others confirm the correctness of relating the differential equation to simple harmonic motion and provide insights into the general solution for such equations. There is a recognition of the need to clarify terminology and the implications of the equations being discussed.
Participants are navigating the complexities of angular motion and the specific definitions of terms like angular frequency and angular velocity. There is an emphasis on ensuring the correct application of mathematical principles related to harmonic motion.
Melawrghk
I have to show the formula derivation of this:
[tex]T=2*pi*\sqrt{\frac{2IL}{pi*r^{4}*G}}[/tex]
based on the fact that I know this:
[tex]\tau=I\alpha=\frac{pi*G*r^{4}}{2L}\theta[/tex]
See above
Well, I know T=2pi/[tex]\omega[/tex] and [tex]\alpha=\Delta\omega/\Delta(t)[/tex]
So I decided to just get an equation for omega from the expression for tau.
So I had:
d[tex]\omega[/tex]/dt=[tex]\frac{pi*G*r^{4}}{2IL}\theta[/tex]
Which looked promising until I integrated both sides wrt 't' and got:
[tex]\omega=\frac{pi*G*r^{4}}{2IL}\theta*t[/tex]
And this really gets me nowhere and I don't know what else to do. Thanks in advance for the help!
You mixed up two VERY different [tex]\omega[/tex]'s
One is angular frequency and the other is angular velocity. They are completely unrelated.
Look at your net torque equation, it is a differential equation of the form [tex]\ddot x=-kx[/tex] (Remember that it is a restoring torque, so you missed a negative sign)
You should be very familiar with the general solution to that equation.
I suggest that you use [tex]\Omega[/tex] for angular velocity instead, to prevent further mixups.
Well, it's familiar and it's from SHM.
There was the d''f(t)/dt''=-omega^2 * f(t) when f(t)=Asin(omega*t+phi)
If I make theta(t)=f(t), then that k would equal omega^2 (the angular frequency omega)
Is that correct though?
That is 100% correct. :)
Once you have the differential equation:
[tex]\ddot \theta=-\Omega^2 \theta[/tex]
The solution should be something that immediately pops into your head:
[tex]\theta (t) = A\cos{(\Omega t +\phi)}[/tex]
And the period for a harmonic function is something you can easily find,
[tex]T=\frac{2\pi}{\Omega}[/tex]
On a side note, when you tried to integrate:
[tex]d\omega = -k\theta \cdot dt[/tex]
You overlooked the fact that [tex]\theta[/tex] is a function of time. That was the source of your error. I was mistaken in thinking you got angular velocity and frequency mixed up.
  • · Replies 20 ·
