Gauss's TheoremNet Force due to Uniform Pressure on a Closed Surface = 0
The discussion centers on the application of Gauss's Theorem in fluid mechanics, specifically regarding the net force due to uniform pressure on a closed surface, expressed mathematically as F = ∫_{surface} p(-n) dA = 0. The user, Casey, seeks clarification on how Gauss's Theorem, which relates volume integrals to surface integrals, applies to a scalar pressure field. The conversation highlights the importance of recognizing pressure as a vector quantity with direction, leading to the reformulation of the theorem as ∫_{Vol} (∇·(p(-n))) dV = ∫_{surface} p(-n) dA.
  • Understanding of Gauss's Theorem and its relation to vector calculus
  • Familiarity with fluid mechanics concepts, particularly pressure and forces
  • Knowledge of vector fields and surface integrals
  • Basic principles of multivariate calculus
  • Study the Divergence Theorem and its applications in fluid mechanics
  • Explore the relationship between scalar and vector fields in physics
  • Review examples of applying Gauss's Theorem to various geometries
  • Investigate the implications of uniform pressure in closed systems
Students and professionals in fluid mechanics, physicists, and engineers seeking to deepen their understanding of vector calculus applications in pressure analysis.
Saladsamurai
In my fluid mechanics text, it states that the Net Force due to a uniform pressure acting on a
closed surface is zero or:
[tex]\mathbf{F} = \int_{surface}p(\mathbf{-n})\,dA = 0 \,\,\,\,\,\,\,(1)[/tex]
where n is the unit normal vector and is defined as positive pointing outward from the surface.
The text then states that "...this result is independent of the shape of the surface. This can be proved by using Gauss's Theorem from Vector Analysis..."
I would like to prove this, but it has been over a year since I took multivariate calculus. When I google "Gauss's Theorem" I keep getting the divergence theorem, but fail to see how this is helpful?
The divergence theorem states that:
[tex]\int_{Volume}(\nabla\cdot\mathbf{F})\,dV = \int_{surface}\mathbf{F}\cdot\mathbf{n}\, dS \,\,\,\,\,\,\,\,(2)[/tex]
where F is a differentiable vector field.
So Gauss's Theorem relates a volume integral to a surface integral. In (1) I am clearly dealing with a surface integral.
Can I get a nudge here? Also I am dealing with a pressure field (constant at that). This is a scalar field; why does Gauss's Theorem still apply?
Thanks,
Casey
Okay, I think that I was mistaken when I said
Also I am dealing with a pressure field (constant at that). This is a scalar field...
Clearly pressure has a direction, namely inwards and normal to the control surface.
So if pressure is uniform, I would write Gauss's Theorem as
[tex]\int_{Vol}(\nabla\cdot\mathbf{p})\,dV = \int_{surface}p(\mathbf{-n})\,dA[/tex]
or
[tex]\int_{Vol}(\nabla\cdot(p\mathbf{-n}))\,dV = \int_{surface}p(\mathbf{-n})\,dA \,\,\,\,\,\,(3)[/tex]
This look better?
EDIT: I feel like I am almost there. But I don't know if the form of (3) helps me..
Any thoughts on this one?
