What is the Potential Energy of a Twisted Spiral Spring?
The potential energy of a twisted spiral spring can be calculated using the torque applied and the angle of twist. In this case, a torque of 60 Nm is applied to twist the spring by 7°. The potential energy (PE) can be derived from the relationship between torque, angle, and the spring constant, which can be determined through the formula PE = 0.5 * k * θ², where k is the spring constant. The discussion emphasizes the need to find the spring constant to complete the calculation.
  • Understanding of torque and its units (Nm).
  • Familiarity with the concept of potential energy in rotational systems.
  • Knowledge of the spring constant and its significance in spring mechanics.
  • Basic grasp of angular displacement and its measurement in degrees.
  • Research how to calculate the spring constant from torque and angle.
  • Learn about the formula for potential energy in rotational motion.
  • Explore the relationship between torque, angular displacement, and potential energy.
  • Study examples of potential energy calculations in twisted springs.
Physics students, mechanical engineers, and anyone studying rotational dynamics and spring mechanics will benefit from this discussion.
Sumbhajee
A spiral spring is twisted from its equilibrium position through θ = 7° by an average torque of 60 Nm. What is its potential energy in Joules?
http://schubert.tmcc.edu/res/msu/mmp/kap8/picts/spring2.gif
I am not even sure how this is possible without the spring constant.. Any help would be greatly appreciated.
You know the torque and how much the string is twisted. Surely you can find the spring constant?
In linear motion problems we have a formula for work in terms of force and displacement. You need to find the formula that is analogous to this but used for rotational motion.
  • · Replies 28 ·
19K
