Thread Closed
orbital angular momentum problem
Share Thread Thread Tools
Oct18-09, 11:31 PM   #1
Consider a particle that moves in three dimensions with wave function [tex] \varphi[/tex] . Use operator methods to show that if [tex]\varphi[/tex] has total angular momentm quantum number l=0 , then [tex]\varphi[/tex] satifies
[tex] L\varphi=0[/tex]
for all three components [tex]L_\alpha[/tex] of the total angular momentum L
2. Relevant equations
[tex] [L^2,L_\alpha][/tex]?
[tex] L^2=L_x^2+L_y^2+L_z^2 [/tex]?
[tex] L^2=\hbar*l(l+1)[/tex] , l=0,1/2,1,3/2,... ?
[tex] L_z=m\hbar[/tex] , m=-l, -l+1,...,l-1,l. ?
3. The attempt at a solution
[tex] [L^2,L_\alpha]=[L_x^2+L_y^2+L_z^2,L_\alpha]=[L_x^2,L_\alpha]+[L_y^2,L_\alpha]+[L_z^2,L_\alpha][/tex]. [tex][AB,C]=A[B,C]+[A,C]B[/tex]; Therefore,[tex] [L_x^2,L_\alpha]+[L_y^2,L_\alpha]+[L_z^2,L_\alpha]=L_x[L_x,L_\alpha]+[L_x,L_\alpha]L_x+L_y[L_y,L_\alpha]+[L_y,L_\alpha]L_y+L_z[L_z,L_\alpha]+[L_z,L_\alpha]L_z[/tex]. Now what?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Oct19-09, 04:34 PM   #2
People having a hard time reading the problem?
Oct19-09, 04:40 PM   #3
Recognitions:
Homework Helper Homework Help
Do you not already know [itex][L^2,L_x][/itex], [itex][L^2,L_y][/itex] and [itex][L^2,L_z][/itex]?
If so, just calculate [itex][L^2,L_x]\varphi[/itex], [itex][L^2,L_y]\varphi[/itex] and [itex][L^2,L_z]\varphi[/itex] and use the fact that [itex]L^2\varphi=l(l+1)\varphi=0[/itex] for [itex]l=0[/itex].
Oct19-09, 08:50 PM   #4
Recognitions:
I don't understand gabbagabbahey's method. I would (using bra-ket notation) define three states [itex]|\psi_i\rangle = L_i|\phi\rangle[/itex], [itex]i=x,y,z[/itex], and then compute [itex]\sum_{i}\langle\psi_i|\psi_i\rangle[/itex].
Oct19-09, 09:25 PM   #5
Quote by gabbagabbahey View Post
Yes I calculated those commutators [tex][L^2,L_x]\varphi=(L_y*i\hbar*L_z)+(i*\hbar*L_z)(L_y)+L_z(i*\hbar*L_y)+(i*\hbar*L _y)L_z,[L^2,L_y]= L_x(i*\hbar*L_z)+(i*\hbar*L_z)L_y+L_z(i*\hbar*L_x)+(i*\hbar*L_x) +(i*\hbar*L_x)L_z, [L^2,L_z]=L_x(i*\hbar*L_y)+(i*\hbar*L_y)(L_x)+L_y(i*\hbar*L_x)+(i*\hbar*L_x)L_y [/tex], The comutators simply expand more and do not simplify . at [tex] l=0, l(l+1)\varphi=0[/tex]
Please look at my latex for the expression [tex][L^2,L_z][/tex] PF is not completely showing the solution to this expression for some reason. Now is it readable
Oct19-09, 09:34 PM   #6
Recognitions:
What you've just written is completely unreadable....How do you expect others to be able to help you, if you don't take the time to make sure they can read what you are posting?
Begin by calculating the commutator [itex][L^2,L_x][/itex]....use the "go advanced" and "preview post" buttons to make sure whatever you write is actually readable, before submitting your post.
Oct19-09, 09:44 PM   #7
[tex]
[L^2,L_x]\varphi=(L_y*i\hbar*L_z)+(i*\hbar*L_z)(L_y)+L_z(i* \hbar*L_y)+(i*\hbar*L_y)L_z,[L^2,L_y]= L_x(i*\hbar*L_z)+(i*\hbar*L_z)L_y+L_z(i*\hbar*L_x) +(i*\hbar*L_x) +(i*\hbar*L_x)L_z, [L^2,L_z]=L_x(i*\hbar*L_y)+(i*\hbar*L_y)(L_x)+L_y(i*\hbar*L _x)+(i*\hbar*L_x)L_y
[/tex] Now is it readable? [tex][L^2,L_z]=L_x(i*\hbar*L_y)+(i*\hbar*L_y)(L_x)+L_y(i*\hbar*L _x)+(i*\hbar*L_x)L_y[/tex]
Oct19-09, 09:49 PM   #8
Recognitions:
I still can't make heads or tails of what you've written....When you read a textbook or article, or even someone else's posts here....do they lay things out in a jumbled mess like that?
Oct19-09, 10:38 PM   #9
I will seperate my commutators into seperate latex code and aligned the commutators vertically. Maybe it should then be easier for you to read:
[tex][L^2,L_x]\varphi=(L_y*i\hbar*L_z)+(i*\hbar*L_z)(L_y)+L_z(i* \hbar*L_y)+(i*\hbar*L_y)L_z[/tex]
[tex][L^2,L_y]\varphi= L_x(i*\hbar*L_z)+(i*\hbar*L_z)L_y+L_z(i*\hbar*L_x) +(i*\hbar*L_x) +(i*\hbar*L_x)L_z[/tex]
[tex][L^2,L_z]\varphi=L_x(i*\hbar*L_y)+(i*\hbar*L_y)(L_x)+L_y(i*\hbar*L _x)+(i*\hbar*L_x)L_y[/tex],
at[tex]l=0, l(l+1)\varphi=0[/tex]
Oct19-09, 10:44 PM   #10
Recognitions:
That's a little easier to read (Although I really wish you'd stop using that ugly [itex]*[/itex] symbol for multiplication). Why do you have a [itex]\varphi[/itex] on the LHS of each equation? And, you are missing some negative signs on the RHS....why don't you show me your steps for calculating [itex][L^2,L_x][/itex]?
Oct19-09, 11:07 PM   #11
okay.[tex] [L^2,L_x]=[L_x^2+L_y^2+L_z^2,L_x]=[L_x^2,L_x]+[L_y^2,L_x]+[L_z^2,L_z][/tex]
[tex][L_x^2,L_x]+[L_y^2,L_x]+[L_z^2,L_x]=[L_y^2,L_x]+[L_z^2,L_x][/tex]
[tex][L_y^2,L_x]+[L_z^2,L_z]=L_y[L_y,L_x]+[L_y,L_x]L_y+L_z[L_z,L_x]+[L_z,L_x][L_z][/tex]
[tex] [L_y,L_x]=i*\hbar*L_z, [L_z,L_x]=i*\hbar*L_y[/tex], therefore
[tex]L_y[L_y,L_x]+[L_y,L_x]L_y+L_z[L_z,L_x]+[L_z,L_x][L_z]=i*L_y(\hbar*L_z),+i*\hbar*L_z*L_y+i*L_z*(\hbar*L_y)+i(\hbar*L_y)*L_z[/tex] .How did you get a negative term? (Sorry, if I don't used the [tex] * [/tex] symbol, latex will read the i's and L's as a subscript rather than a coeffcient
Oct20-09, 01:26 AM   #12
Recognitions:
[itex][L_y,L_x]=-[L_x,L_y]=-i\hbar L_z[/itex]
Oct20-09, 06:18 AM   #13
My calculations showed that [tex] [L^2,L_z]=0,[L^2,L_y]=0,[L^2,L_x]=0[/tex], now what?
Oct20-09, 07:00 AM   #14
Recognitions:
Now, by definition what is [itex][L^2,L_x]\varphi[/itex]?...compare that to what you've just calculated....
Oct20-09, 07:09 AM   #15
since[tex][L^2,L_x]=0[/tex],then[tex][L^2,L_x]\varphi=0\varphi=0[/tex]?
Oct20-09, 07:24 AM   #16
Recognitions:
If I asked you the definition of [itex][A,B]\varphi[/itex], you would say [itex](AB-BA)\varphi[/itex], right?
So, when I say "by definition what is [itex][L^2,L_x]\varphi[/itex]?", you say ____?
Oct20-09, 07:51 AM   #17
yes thats right. [tex][L^2,L_x]=(L^2L_x-L_xL^2)\varphi[/tex], should I let [tex]L_x=(\hbar/i)*d/dx[/tex] and [tex] L=(\hbar/i)*d/dx+(\hbar/i)*d/dy+(\hbar/i)*d/dz[/tex] and let [tex] (-\hbar/i)*d/dx+(-\hbar/i)*d/dy+(-\hbar/i)*d/dz[/tex]
Thread Closed
Thread Tools
Similar Threads for: orbital angular momentum problem
Thread Forum Replies
Orbital Angular Momentum and Uncertainty? Quantum Physics 2
Orbital and Spin angular momentum Advanced Physics Homework 4
Orbital Angular Momentum Advanced Physics Homework 4
Angular momentum and orbital angular momentum problems Introductory Physics Homework 3
orbital angular momentum Quantum Physics 10
