Understanding How Seals Work on Autoclaves
  • Thread starter Thread starter Andronicus1717
    Work
The discussion focuses on the sealing mechanism of autoclaves, particularly the role of the rotatable bayonet ring and the O-ring face seal. The O-ring, identified as the red ring in the provided image, serves as a critical component for maintaining pressure within the chamber. The sealing force is primarily generated by the wedging action of the bayonet ring, which is designed to withstand high pressure while remaining rotatable. Additionally, the conversation touches on the need for suitable lubricants for EPDM autoclave seals to ensure optimal performance.
  • Understanding of autoclave design and operation
  • Familiarity with O-ring sealing technology
  • Knowledge of pressure vessel engineering principles
  • Experience with lubricants suitable for EPDM materials
  • Research the mechanics of bayonet coupling systems in pressure vessels
  • Explore the properties and applications of EPDM seals in high-pressure environments
  • Learn about effective lubricants for O-ring seals in autoclaves
  • Investigate thermal insulation techniques for sealing components in autoclaves
Engineers, technicians, and researchers involved in the design, maintenance, or operation of autoclaves and other high-pressure vessels.
Andronicus1717
How does the seal work on a large resealable high pressure vessel such as an autoclave?
example: http://gust.engin.umich.edu/autoclave2.jpg
If you look at the example above you always see the rotatable bayonet ring attached to the vessel. The red ring is probably the o-ring face seal on the chamber. The concentric rings on the end I assume are for thermal insulation of the red o-ring seal on the vessel.
Is it the wedging of the bayonet ring that provides the normal sealing force or is there something that I'm missing? And how is that ring secured to the vessel itself while being rotatable and stiff enough to support all the pressure on the flange while in operation? Or is the flange the rotatable part (that would make more sense)?
On this subject can anyone help with a good lubricant for EPDM autoclave seals ?
12K
  • · Replies 21 ·
