Optimizing Reactive Power Injection with a Single Phase Inverter
This discussion focuses on optimizing reactive power injection using a single-phase inverter with a constant DC bus voltage maintained above 169.71V for a 120V RMS AC output. Key insights include the importance of AC terminal RMS voltage in MVAR generation and the necessity of feedback mechanisms to regulate AC RMS voltage effectively. The use of a PI control system is confirmed as adequate for this application, while alternative approaches like feed-forward compensation are suggested for further exploration.
  • Understanding of single-phase inverter operation
  • Knowledge of reactive power and MVAR generation
  • Familiarity with PI control systems
  • Basic concepts of AC voltage regulation
  • Research methods for implementing feedback control in inverter systems
  • Explore feed-forward compensation techniques for reactive power injection
  • Study the effects of varying AC terminal RMS voltage on MVAR generation
  • Investigate advanced control strategies for single-phase inverters
Electrical engineers, power system analysts, and anyone involved in the design and optimization of inverter-based reactive power systems.
barrymon
Hello,
I am trying to simulate reactive power injection with a single phase inverter. The constant dc bus voltage on the input side is maintained much higher than 169.71V (considering 120V rms ac output). I have generated the current reference for the control (a PI based system) but it doesn't seem enough. Can anyone there let me know what all factors I should consider? Or is an alternate approach better- like a feed forward compensation? Any help would be appreciated. Has anyone simulated/implemented this previously?
That doesn't make much sense. Only the AC side voltages matter.
The higher the AC terminal RMS voltage, the more positive the MVAR generation. It's that simple. You need to feed back the MVAR to a regulator that can vary the AC RMS voltage. PI control is probably sufficient.
  • · Replies 27 ·
  • · Replies 18 ·
9K
