Eigenfunctions of translation operator and transposed operator property proof
The discussion focuses on finding the eigenfunctions and eigenvalues of the translation operator \(\widehat{T_{a}}\) defined by \(\widehat{T_{a}}\psi(x)=\psi(x+a)\). The eigenfunctions are established as \(\psi_{n}(x)=e^{x+2n\pi i}\) with corresponding eigenvalues \(c_{n}(a)=e^{a+2n\pi i}\). Additionally, the discussion touches on the inversion operator \(\widehat{I_{x}}\) and its eigenvalues, which are \(f_{1}=1\) and \(f_{2}=-1\). A secondary problem involves proving the property \((AB)^{T}=B^{T}A^{T}\) using bra-ket notation and integral forms, although the user expresses uncertainty in their approach.
  • Understanding of eigenvalue problems in linear operators
  • Familiarity with the translation operator in functional analysis
  • Knowledge of bra-ket notation and transposed operators
  • Basic complex analysis, particularly with exponential functions
  • Study the properties of linear operators in functional analysis
  • Learn about the spectral theorem for self-adjoint operators
  • Explore the implications of eigenvalues in quantum mechanics
  • Investigate the proof techniques for operator properties in linear algebra
Mathematicians, physicists, and students studying quantum mechanics or functional analysis, particularly those interested in operator theory and eigenvalue problems.
Muchacho
Find the eigenfunctions and eigenvalues of the translation operator [tex]\widehat{T_{a}}[/tex]
Translation operator is defined as [tex]\widehat{T_{a}}\psi(x)=\psi(x+a)[/tex] (you all know that, probably you just call it differently)
The eigenvalue/eigenfunction equation is given like
[tex]\widehat{T_{a}}\psi_{n}(x)=f_{n}\psi_{n}(x)[/tex]
I write the eigenvalues [tex]f_{n}[/tex] are in the form of [tex]c_{n}(a)[/tex] (c noting that it is a complex coefficient)
And I don't know how to proove it correctly and clearly, but I get that only possible eigenfunctions are exponentials [tex]\psi_{n}(x)=e\ ^{x+2n\pi\i}[/tex] and the eigenvalues for [tex]\widehat{T_{a}}[/tex] are [tex]c_{n}(a)=e\ ^{a+2n\pi\i}[/tex]
I don't have any ideas how to proove it more clearly, because this "solution" involves more thinking and assuming than solving.
I also did similar solution for inversion operator [tex]\widehat{I_{x}}\psi(x)=\psi(-x)[/tex] by finding eigenvalues just looking at the properties of an equation which was like [tex]\psi(-x)=f\psi(x)[/tex] and using the property of odd and even functions and thus finding 2 eigenvalues of [tex]f_{1}=1[/tex] and [tex]f_{2}=-1[/tex] and thus getting infinite number of eigenfuntions. The real solution to this problem was using the property that [tex]\widehat{I_{x}}^2=\widehat{1}[/tex] and modify the equation [tex]\widehat{I_{x}}\psi(x)=f\psi(x)[/tex] by multiplying both sides from the left with [tex]\widehat{I_{x}}[/tex] and thus getting [tex]\psi(x)=f^{2}\psi(x)[/tex] and just needed to solve the quadratic equation of [tex]f^{2}=1[/tex] thus getting the same values of [tex]f_{1}=1[/tex] and [tex]f_{2}=-1[/tex] This was just an example of possible ways to solve eigenvalue equations, but in this case - the real solution shows that no other solutions are possible.
And also I have this second problem which is more like proof of a formula which is usually given as a property.
Proove that [tex](AB)^{T}=B^{T}A^{T}[/tex]
The transposed operator is given in bra-ket notation as [tex]\left\langle\varphi\left|\widehat{A}^{T}\right|\psi\right\rangle=\left\langle\psi^{*}\left|\widehat{A}\right|\varphi^{*}\right\rangle[/tex] or in integral form as [tex]\int\varphi(x)\widehat{A}^{T}\psi(x)dx=\int\psi(x)\widehat{A}\varphi(x)dx[/tex]
Well, I have completely no ideas on where to start with this one.
Because I started with it like [tex]\left\langle\varphi\left|\widehat{AB}\right|\psi\right\rangle=\left\langle\varphi\left|\widehat{A}\right|\widehat{B}\psi\right\rangle=\left\langle\psi^{*}\left|\widehat{A}\right|\widehat{B}^{T}\varphi^{*}\right\rangle[/tex] but I really doubt that the last operation is correct and I'm allowed to do so.
I hope I made my doubts and problems clear and thanks for help in advance!
Welcome to PF!
Hi Muchacho! Welcome to PF! :smile:
(have a psi: ψ :wink:)
Where did you get n from? :confused:
Remember, this works for any a.
Hint: take logs of the equation. :smile:
