Action of catalase and MnO2 on hydrogen peroxide
The discussion revolves around the comparative action of catalase and manganese dioxide on hydrogen peroxide, focusing on an experimental setup involving various test tubes with different substances. Participants explore the biochemical mechanisms involved, the effects of heat on enzymes, and the role of inorganic catalysts.
  • Experimental/applied
  • Some participants identify the enzyme present in liver as catalase, which is responsible for the reaction in tube A.
  • There is a suggestion that tube B will show a negative reaction due to the denaturation of the enzyme from boiling the liver, raising questions about enzyme stability.
  • Participants note that manganese dioxide acts as an inorganic catalyst for breaking down hydrogen peroxide, contrasting it with catalase.
  • One participant proposes that the reaction in tubes C and D will be similar, indicating that manganese dioxide does not lose its catalytic properties upon boiling.
  • There is a hypothesis that repeating the experiments with potato tubers will yield similar results to those with liver, due to the presence of catalase in both substances.
  • Another participant emphasizes the importance of understanding the effects of temperature on enzyme activity and the stability of inorganic catalysts.
  • One participant requests clarification on expected outcomes for the experiment and encourages others to articulate their reasoning without directly quoting previous contributions.
Participants generally agree on the roles of catalase and manganese dioxide, but there are differing views on the implications of boiling the liver and the expected outcomes of the experiments. The discussion remains unresolved regarding the specific effects of temperature on enzyme activity and the interpretations of observations.
Participants have not yet performed the experiment, and there is uncertainty regarding the specific data and observations that will be recorded. The discussion includes assumptions about the presence of enzymes in the liver and potato tubers, as well as the effects of boiling on enzyme activity.
hikki_pop
can anyone give some comments or inferential analysis to the research presented below? thank you :D some info and answers to the topic questions would be nice to hear too!
"To compare the action of catalase and manganese dioxide on hydrogen peroxide."
1. Label 4 test-tubes A, B, C and D.
2. To each tube add 5cm3 of hydrogen peroxide.
3. Prepare the contents of the 4 tubes as shown in the table below. For each tube record the observations. Test any gas given off with a glowing splinter.
TEST TUBE AND CONTENTS:
A. 5cm3 hydrogen peroxide solution + 1 small pieace of fresh liver
B. 5cm3 hydrogen peroxide solution + 1 small piece of boiled liver (Boil the liver for 10 minutes and cool before use.)
C. 5cm3 hydrogen peroxide + a little manganese (IV) oxide
D. 5cm3 hydrogen peroxide solution + a little boiled manganese dioxode (The manganese dioxide has been boiled and cooled before use.)
4. What type of substance is in the liver which could bring about the reaction in tube A?
5. How do you account for your observation in tube B?
6. From your observation on D, what can you conclude about manganese (IV) oxide?
7.Repeat experiments A and B using a piece of potato tuber.
:smile:
Biology news on Phys.org
What enzyme is present in the liver? It is clearly stated in you title.
The reaction should be negative.
What happen to proteins when you heat it up? What would be the effect on an enzyme? Therefore the enzyme is heat stable or labile?
Manganese dioxide is an inorganic catalyst (but not an enzyme) for the breaking down of hydrogen peroxide. Reaction C & D have the same reaction. Therefore manganese oxide is the opposite of catalase
It should give the same reaction as with the liver piece. Why? same enzyme is present in the potato.
http://www.google.ca/search?q=cache:SiNuE31QS-kJ:www.uq.edu.au/_School_Science_Lessons/topic17.html+compare+action+catalase+%22manganese+dioxide%22+%22hydrogen+peroxide%22&hl=en
Have you performed this experiment yet? You didn't show your data.
nope we didn't do it yet...
Did your manual or instructor specify that catalase in present in both the liver and in potato tubers? If not, ian probably shouldn't have given that away. Have you learned yet about the effects of temperature on the activity of enzymes and on inorganic catalysts? I'm going to assume you have, but if not, ian kind of gave that one away as well. Just to reiterate the point, boiling the liver will denature the enzyme (as it would any protein), and without the proper conformation for its active site, the enzyme will cease to function. Boiling the manganese dioxide, on the other hand, will have no effect and that reaction should proceed as if you had never boiled the catalyst.
I believe you are breaking down hydrogen peroxide into water and elemental oxygen, so that positive reactions will give off oxygen gas, which will ignite your glowing splinter. In short, the splinter should light up when placed over tubes A, C, and D, but not when placed over tube B. Now, just to review, can you tell me why this is and give your expected answers for questions 4 -7 (without directly quoting ian or myself)?
9K
