Single or multiple random number generators?
Using a single instance of the Java Random class is generally more efficient than creating multiple instances. A single Random object minimizes resource consumption, as instantiating new objects incurs additional processor and memory overhead. Reusing the same seed with a single Random instance allows for consistent random number generation, which is beneficial for debugging and comparisons. Therefore, unless the application specifically requires multiple independent random sequences, a single Random object is the preferred approach.
  • Java programming language
  • Understanding of the Random class in Java
  • Knowledge of object-oriented programming concepts
  • Familiarity with debugging techniques in Java
  • Explore Java Random class documentation for advanced features
  • Learn about seeding techniques in random number generation
  • Investigate performance implications of object instantiation in Java
  • Study alternatives to Java Random, such as SecureRandom for cryptographic applications
Java developers, software engineers, and anyone interested in optimizing random number generation in their applications.
mtanti
I'm programming in Java and using the Random class and I'm not sure if it makes a difference whether I use a single accessible Random object for the whole program or if I should create multiple instances (one for each object needing it?). Are there disadvantages to using one instead of the other?
I'm assuming that it would help to be able to reuse the same seed on a single random object in order to re-create the same sequence of random numbers during debugging and comparisons.
Thanks.
Technology news on Phys.org
Thanks.
It depends on the application. If you can get away with just one that is best. Instantiating new objects takes both processor and memory resources.
  • · Replies 21 ·
9K
