Multi-variable integration with polar coordination
The discussion revolves around a double integral involving the function sin(x^2 + y^2) over a specified region defined by the inequalities 4 ≤ x^2 + y^2 ≤ 49. The problem requires converting Cartesian coordinates to polar coordinates for integration.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the conversion of the integral into polar coordinates and the implications of the specified region. Questions arise regarding the bounds for r and θ, with some participants initially misunderstanding the limits of integration.
Participants have explored various interpretations of the bounds for r and θ, with some reaching a clearer understanding of the integration limits. Guidance has been provided on the correct setup of the integral, though some confusion remains regarding the implications of the integrand and the nature of the result.
There is a noted distinction between computing the area of the region and evaluating the integral of the function sin(x^2 + y^2), which leads to discussions about the potential for negative results in the context of the integral.
MasterWu77
[tex]\int[/tex][tex]\int[/tex] of R ( sin( x^2 + y^2) ) dA where the region 4[tex]\leq[/tex] x^2+y^2 [tex]\leq[/tex] 49
not too sure but i know that dy dx = r d(r) d(theta)
i don't understand how to change into polar coordinates in order to integrate. I'm unsure of how the 4[tex]\leq[/tex] x^2+y^2 [tex]\leq[/tex] 49 becomes the r i need to integrate with. and if i do get that then how do i change the other bounds of integrate for the d (theta)
What does "of R" mean in your integral? Does it represent the region you are describing, or is it some factor in the integrand?
The region described by the inequalities is an annulus (a shape like a washer) that lies outside the circle x^2 + y^2 = 4 and inside the circle x^2 + y^2 = 49. In this region, r is going to be between two values.
Your integrand is pretty simple to change to polar coordinates, since r^2 = x^2 + y^2.
the R refers to the region that is being described. sorry for not clarifying that earlier.
so with r^2 = x^2 + y^2, does that mean the bounds of d(r) would be from 4 to 49? and if so then would the bound of the integral for d(theta) be from 0 to 2(pi) since it is a complete circle?
r does NOT range from 4 to 49. Draw the circles and it should be clear to you why this is so.
[itex]\theta[/itex] does range from 0 to 2[itex]\pi[/itex].
ah ok. i believe i see what you mean.
after looking at the circles i think i see that r ranges from 2 to 7 which would be the radius of the circles. and so from there on do i just need to a double integral of sin(r^2) r dr d(theta)? or is there some other little step I'm missing?
That's pretty much it. Your integral should look like this:
[tex]\int_{\theta = 0}^{2\pi}\int_{r = 2}^7 sin(r^2) r dr d\theta[/tex]
ok awesome. i got that integral and then attempted to solve for it.
i used a u substitution for the sin(r^2) where:
u=r^2
du= 2rdr
and i ended up with
-(1/2) [tex]\int cos(u)d(theta)[/tex]
where the integral is bounded from 0 to 2(pi) and the cos (u) goes from 4 to 49 because of the u substitution i used. i put the answer in and it said that it was incorrect
Your second integral should look like this:
[tex](-1/2)\int_{\theta = 0}^{2\pi}\left(cos(49) - cos(4)\right) d\theta[/tex]
Edit: Added multiplier to front of integral.
ok i got that but shouldn't there be a (-1/2) out in front of the integral to account for the u substitution?
when i solve for the integral should i get
[(cos(49)-cos(4))* 2pi]
since the there isn't originally a [tex]\theta[/tex] so by taking the integral with respect to [tex]\theta[/tex] a [tex]\theta[/tex] should appear which can be bounded by the 2pi and 0
Yes, it was in my notes, but I neglected to put that in my post.
Yes, but you need to put in the missing (-1/2). If you evaluate your answer, remember that the numbers are real numbers (i.e., radians), not degrees.
ah ok i finally got the right answer! it turns out that the answer is negative but i didn't think that was possible since we're computing an area so wouldn't the answer be a positive number?
No, you're not computing the area of the region R. If you were, the integrand would be 1, not sin(x^2 + y^2). A lot of the surface z = sin(x^2 + y^2) must lie below the x-y plane for the integral to come out negative.
o ok that makes sense! thank you very much for helping me with this problem and helping me to understand the concept better :smile:
  • · Replies 19 ·
  • · Replies 105 ·
13K
