Geosynchronous Orbits: Explaining Relativistic Motion
  • Context: Graduate
  • Thread starter Thread starter Charlie G
    Orbits
The discussion revolves around the understanding of geosynchronous orbits from a relativistic perspective, exploring how relativity applies to objects in such orbits and the implications for observers on Earth. It touches on concepts of inertial and non-inertial frames of reference, gravitational forces, and the effects of relativity in practical applications like GPS.
  • One participant expresses confusion about why a geosynchronous satellite does not fall towards Earth, suggesting that it should according to the principle of relativity.
  • Another participant questions the application of Special Relativity to the scenario, implying that the principle may not hold in non-inertial frames.
  • A participant clarifies that the principle of relativity applies to inertial frames, and that a rotating frame (like that of the Earth) introduces centrifugal forces that must be considered.
  • Some participants discuss the misunderstanding of the general principle of relativity, with one suggesting that it applies to all frames, including non-inertial ones.
  • There is a suggestion that the gravitational field provides the necessary acceleration for circular motion, which could explain why the satellite remains in orbit.
  • References to relativistic corrections in GPS systems are mentioned, indicating practical implications of these concepts.
Participants express differing views on the application of relativity to geosynchronous orbits, particularly regarding inertial versus non-inertial frames. There is no consensus on the implications of these principles for the behavior of satellites in orbit.
Participants highlight the need to consider centrifugal forces in rotating frames and the potential misunderstanding of how relativity applies in different contexts. There are unresolved aspects regarding the interpretation of gravitational effects in non-inertial frames.
Charlie G
I was having trouble making sense of the geosynchronous orbits from a relativistic point of view. Correct me if I am wrong, but in a geosynchronous orbit the object appears to hover over a certain place on the Earth, from the point of view of the Earth, which can be said to be at rest according to the principle of relativity, the object is at rest above the Earth.
Therefore, should the general pinciple of relativity hold true, the object should begin to fall towards the Earth in a straight line relative to an observer on the Earth's surface.
This obviously doesn't happen, but I have good faith that there exist a solution somewhere in the theory, which is why I have addressed my troubles here.
Thank-you.
Just what is it in the Special Relativity that makes you think this is true?
The principle of relativity applies to inertial frames. A frame attached to "a certain place on the Earth", where the geosynchronous satellite is at rest, is an rotating frame of reference. In rotating frames of reference you have centrifugal forces:
http://en.wikipedia.org/wiki/Centrifugal_force_(rotating_reference_frame)
Yes, that is correct.
How does that follow?
Thank-you.
Thanks for the replies. I suppose my troubles only lied in my confusion about relativity, I had assumed tht the general principle applied to all frames of reference, even non-inertial frames, so that even an observer in one could call himself at rest and attribute inertial forces to a gravitating body. I must read my book for a second time for I seem to have misunderstood.
This sounds fine to me... I don't get why you think the satellite will fall though? It is in an orbit with no resistance, the gravitational field provides the acceleration required for circular motion, don't you think it would stay where it is?
Not in a co-rotating frame of reference where the satellite is at rest. There you need to introduce the centrifugal force to keep it from falling. That's what the OP forgot.
  • · Replies 51 ·
  • · Replies 99 ·
  • · Replies 18 ·
