Conservation of Kinetic Energy Proof
The discussion revolves around a problem involving a perfectly elastic collision between two pool balls, where the goal is to prove that the angles of their velocities after the collision sum to 90 degrees. The context is rooted in the principles of conservation of energy and momentum.
  • Mixed
  • Participants explore the application of conservation laws, questioning the correctness of initial equations and the relevance of direction in kinetic energy calculations. There is a focus on the relationship between angles and velocities post-collision.
Some participants have provided clarifications regarding the nature of kinetic energy and its independence from direction, while others suggest that additional momentum equations could be beneficial. The discussion is ongoing, with participants actively seeking to refine their understanding and approach.
There is a noted confusion regarding the initial problem statement and the application of conservation principles, as well as the potential for algebraic errors in the original poster's equations.
Davey Boy
[EDIT]Title is incorrect, it is a proof using Conservation of Energy/Momentum
You take a pool shot for the win. The perfectly [EDIT]elastic[/EDIT] collision is such that after the collision the Que ball has a non-zero velocity along angle [tex]\theta[/tex], and the 8 ball has a non-zero velocity along angle [tex]\beta[/tex]. Prove that [tex]\theta[/tex]+[tex]\beta[/tex]=90[tex]\circ[/tex]. The two pool balls have exactly the same mass.
No equations are given, but I am fairly certain only [tex]\Delta[/tex]K=[tex]\Delta[/tex]P=0 is needed. My teacher vaguely hinted that those were the equations/principals he recommend we utilize.
I came up with 2 equations:
1) [1/2]M*VIQ2=[1/2]M*VFQ2*cos([tex]\theta)[/tex]+[1/2]M*VF82*cos([tex]\beta[/tex])
2) M*VIQ=M*VIQ*cos([tex]\theta)[/tex]+M*VF8cos([tex]\beta[/tex])
I solved for VFQ and plugged that into the 1st equation. After simplifying I got;
2[(VF8cos([tex]\beta[/tex]))(VFQcos([tex]\theta[/tex]))]=0
I figured out that this means one of those variables must be 0.I know that VFQ is not, and VF8 is not, therefore, one of the angles must be equal to 90[tex]\circ[/tex] for that equation to equal 0.
I believe my initial equations are wrong, though i could have easily made an algebraic mistake. Any pointers would be very nice, Thanks!
Hi Davey Boy, welcome to PF.
Are you sure that the problem statement shouldn't say "the perfectly elastic collision?" If not, then why are you using conservation of kinetic energy?
Your first equation, (the energy equation), is wrong. Why do you have those cosine factors in there?
It should be elastic rather than inelastic, my mistake. I'll edit that part. I have the cosine factors to account for the angle at which the pool balls are traveling after the collision. I know those are needed for the momentum equation because my teacher did a brief example for 2-D momentum problems, but are they not for kinetic energy?
Energy doesn't have a direction. The kinetic energy of a ball ( its energy due to motion) depends upon its *speed*, i.e. the magnitude of its velocity. So KE = (1/2)mv2, period. The energies of the two balls after the collision must add up to the energy of the que ball before.
Awesome, that's what I had suspected. Thanks for the help, I'll try that out and get back to you if it works or not.
Thanks to the hint of energy not being a vector, thus not requiring a direction, I was able to find equations for VFQ and VF8. I have no idea what to do now though. The equations I got are:
VFQ=[tex]V_{IQ}(cos\beta-1)/(cos\beta-cos\theta)[/tex]
and
VF8=[tex]V_{IQ}(1-cos\theta)/(cos\beta-cos\theta)[/tex]
Hey, well I noticed that your momentum conservation equation was only for conservation of momentum in one direction. There's also conservation of momentum in the other, perpendicular direction (which gives you another equation to play with). That equation will relate VF8 to VFQ.
