Force necessary to spin an alternator at the rated RPM?
The discussion revolves around determining the force necessary to spin an alternator at its rated RPM, focusing on theoretical calculations, practical considerations, and specific examples related to alternators used in generators.
  • Some participants suggest that the force required to spin an alternator depends on specific properties of the alternator, including internal friction and the time taken to reach the rated RPM.
  • Others note that the electrical load on the alternator also influences the force necessary to achieve the rated RPM.
  • One participant proposes a hypothetical scenario involving a 6000 watt generator head and questions whether it is possible to determine the necessary force without knowing specific details like mass and friction.
  • Another participant mentions that approximately 5 horsepower is needed for a 100 amp alternator.
  • A technical explanation is provided regarding the relationship between torque, angular speed, and power output, including a formula for calculating torque based on power and RPM.
  • One participant warns that real-world alternators typically operate at about 40% efficiency, indicating a discrepancy between calculated horsepower and the actual horsepower required to turn the alternator.
Participants express differing views on the factors influencing the force necessary to spin an alternator, with no consensus reached on a definitive method or calculation. The discussion remains unresolved regarding the specific force requirements under varying conditions.
Limitations include the lack of specific details about the alternator's properties, such as mass and friction, which are necessary for accurate calculations. The discussion also highlights the dependence on efficiency ratings, which can significantly affect the required horsepower.
eli_lied
Can anyone tell me how to determine the force necessary to spin an alternator at the rated RPM?
No, because that depends upon properties of the specific alternator. In particular, the friction in the alternator itself and the time in which it is brought up to that RPM.
ok hypotheically then, let's say it's a 6000 watt generator head taken from a portable home backup generator. if i have 6400lbs-ft of constant force and the generator head operates at either 3600 rpm or 1800 rpm...without knowing the specific details such as mass(approx. 60-80lbs of rotational parts) or friction, is it possible to determine the force necessary? also does anyone know of a website that offers detailed information on alternators and/or suppliers that I could purchase one from?
about 5 horsepower for 100 amp alternator
Torque (Newton-meters) in angular rotation is the equivalent to force (Newtons) in linear motion. For an alternator, the power output (watts) is the product of the angular force times the angular speed. Specifically
T x 2 pi RPM/60 = W watts, where the torque T is in Newton-meters.
So for a 6000 watt alternator output (at 100% efficiency) at 3600 RPM, the torque is
T = 60 W/ 2 pi RPM = 15.9 Newton-meters.
6000 watts (at 100% efficiency) is equal to 8.04 HP
Bob S
be advised that in the real world alternators are 40% efficient which is why there is a difference between calculated HP and actual parasitic HP required to turn the Alt.
  • · Replies 26 ·
  • · Replies 19 ·
  • · Replies 60 ·
