How Far Can a 300 mm Telescope Resolve a Double Star Separated by 10 AU?
  • Context: Undergrad
  • Thread starter Thread starter radiosource
    Optical Resolution
A 300 mm telescope can resolve a double star system separated by 10 astronomical units (AU) at a maximum distance of approximately 1.5 light years or 0.46 parsecs. The angular resolution is primarily limited by the diffraction limit, which can be calculated using the formula θ = 1.22 * (λ/D), where θ is the angular resolution in radians, λ is the wavelength of light, and D is the diameter of the telescope aperture. For visible light, using a wavelength of 550 nm, the telescope's resolution allows for the detection of such a double star system within the specified distance.
  • Understanding of angular resolution and diffraction limits in optics.
  • Familiarity with astronomical units (AU) and their conversion to light years and parsecs.
  • Basic knowledge of the formula θ = 1.22 * (λ/D) for calculating angular resolution.
  • Concept of light wavelengths, particularly in the visible spectrum.
  • Research the effects of atmospheric turbulence on telescope resolution.
  • Explore advanced telescope designs that enhance resolution, such as adaptive optics.
  • Learn about the limitations of different telescope apertures in astronomical observations.
  • Study the principles of interferometry and its application in resolving distant astronomical objects.
Astronomy students, amateur astronomers, and anyone interested in understanding telescope capabilities and resolving power in astrophysics.
radiosource
Imagine a double star with components separated by 10 astronomical units (10 AU). How far away can such a system be while remaining resolved with a 300 mm telescope? Show workings and give your final answer in either light years or parsecs. (Ignore atmospheric effects).
Thanks.
Astronomy news on Phys.org
Since this is obviously a homework problem, it should go into the "Homework and Coursework" section. You're also expected to show your attempts at the problem, as well as any relevant equations.
I'll start you off: what limits the angular resolution of a telescope? (In reality the answer is almost always "atmospheric effects", but the question wants you to ignore that.)
  • · Replies 34 ·
15K
9K
