A 100-g piece of metal initially at T = 75oC
  • Thread starter Thread starter physicsman2
    Metal
The problem involves a 100-g piece of iron at an initial temperature of 75°C submerged in 100 g of water at 25°C. Using the specific heat capacities of iron (0.45 J g-1 °C-1) and water (4.18 J g-1 °C-1), the final temperature can be calculated using the equation q=mc(delta T). The correct approach requires setting the heat lost by the metal equal to the heat gained by the water, leading to the equation 100g * 0.45 J g-1 °C-1 * (75°C - Tfinal) = 100g * 4.18 J g-1 °C-1 * (Tfinal - 25°C).
  • Understanding of specific heat capacity
  • Ability to manipulate algebraic equations
  • Familiarity with the concept of thermal equilibrium
  • Basic knowledge of units in thermodynamics
  • Review the principles of thermal equilibrium in thermodynamics
  • Practice solving problems involving heat transfer and specific heat capacity
  • Learn about calorimetry and its applications in physics
  • Explore the concept of conservation of energy in closed systems
Students studying physics or chemistry, particularly those focusing on thermodynamics and heat transfer concepts.
physicsman2
A 100-g piece of metal initially at T = 75oC is submerged in 100 g of water initially at T = 25oC. The specific heat capacity of iron is 0.45 J g-1 °C-1 and the specific heat capacity of water is 4.18 J g-1 °C-1. What is the final temperature of both substances in oC?
q=mc(delta T)
well i tried to set mc(delta T)=mc(delta T), plug in all the values and solve for T(final), but i keep getting the wrong answer
Can you show your work? It is hard to see what your problem is without being able to check your calculations.
