Mixtures of Acids and Bases: What Type of Solution is Produced?
The discussion revolves around the chemical reaction between ammonium chloride (NH4Cl) and sodium hydroxide (NaOH), specifically focusing on the nature of the resulting solution. Participants explore the characteristics of the solution produced, including whether it contains a weak acid, weak base, conjugate acid/base pair, or behaves as a buffer. The scope includes theoretical reasoning and homework-related problem-solving.
  • Homework-related
  • Some participants propose that the solution contains a conjugate acid/base pair, suggesting it may resist pH changes.
  • Others argue that the solution consists of equal amounts of a weak base (NH3) and a salt of the weak base (NH4^1+), raising questions about the pH before and after the reaction.
  • A participant mentions that the equilibrium concentrations indicate a mixture of a weak acid and a weak base, which could classify the solution as a buffer.
  • Some participants express uncertainty about the implications of the equilibrium concentrations and how they relate to the classification of the solution.
  • There is a suggestion that the solution could be classified as containing both a conjugate acid/base pair and a buffer.
  • One participant notes that they arrived at two different pH values in their calculations, indicating potential discrepancies in understanding or methodology.
Participants do not reach a consensus on the classification of the solution. Multiple competing views remain regarding whether the solution should be described as containing a weak acid and a weak base, a conjugate acid/base pair, or a buffer.
There are unresolved aspects regarding the calculations of pH and equilibrium concentrations, as well as the definitions and implications of buffer solutions. Some participants express confusion about the relationships between the various species in solution and their respective concentrations.
This discussion may be useful for students studying acid-base chemistry, particularly those interested in buffer solutions and the behavior of weak acids and bases in solution.
w3390
You prepared a reaction table for 10.0 mL of 0.1 M NH4Cl with 5.0 mL of 0.1 M NaOH. Please choose all of the following that describe the solution that was produced.
The choices are:
1. a solution containing only a strong base
2. a solution containing a weak acid and a strong base
3. a solution containing a weak acid and a weak base
4. a solution containing only a weak base
5. a solution containing a conjugate acid/base pair
6. a solution containing only a strong acid
7. a buffer
8. a solution containing a weak base and a strong acid
9. a solution containing only a weak acid
10. a solution containing a strong acid and a strong base
N/A
I have already completed the table correctly and have found that the produced solution consists of .5 mmol NH4^1+ and .5 mmol NH3.
Using this information I've tried the answers: 5 by itself, and 3 and 5 together. These are both incorrect.
Can anyone help me out on what I'm missing. Any help would be much appreciated.
Solution containing conjugate pair has a specific property - it resists pH changes. Does it ring a bell?
You are converting half of the moles of NH4Cl to NH3. So you have about equal amounts of a weak base and a salt of the weak base. What does this mean? What was the pH of the ammonium chloride solution before any strong base was added? What may be the pH after half of the ammonium chloride was turned back into ammonia?
So it would be 4 and 7? I'm not sure if it would also contain an acid/base conjugate pair.
w3390, excuse this next guiding question - it is meant to push you toward an answer but you may be still unprepared for it: Starting with the weak base, ammonia in solution, where would you expect the first buffer region if you were in the process of neutralizing it with hydrochloric acid?
I have no idea what that means or how to answer it.
I noticed that in your original message question you did not know Relevant Equations, but you found in Attempted Solution, good values for ammonium ion and ammonia. What you need to know about are these, at least to use one of them:
Kb = [tex]\frac{[NH4][OH]}{[NH3]}[/tex]
Ka = [tex]\frac{[NH3][H]}{[NH4Cl]}[/tex]
Kw = [H][OH] = KbKa
Kb for ammonia is about 1.85*10-5
Please excuse the lack of showing charges for the ions. The asterisk was used to show multiplication in Kb value.
I know that the equilibrium concentration of NH4^1+ and NH3 are equal, so that is saying that the OH^1- concentration is equal to Kb. I do not see where this is going.
You essentially have a formula to choose and only one variable is unknown. The process will be simple basic algebra.
I'm really sorry, but I cannot figure out what you are saying. What process will be simple algebra. From what it seems like you're telling me, the answer should be that the solution contains only a weak base since the OH^1- concentration is small. But I am probably completely wrong.
Try writing out the reaction, see what you get.
w3390: what is it in 7?
methods
When I write the reaction I get:
NH4^1+(aq) + OH^1-(aq) --> NH3(aq) + H2O(l)
Using this reaction, I figured out that the equilibrium concentrations are as follows:
[NH4^1+]=.033
[OH^1-]=1.8e-5
[NH3]=.033
[H3O^1+]=5.6e-10
After writing the reaction and finding concentrations, I see that there are equal concentrations of acid and conjugate base and very small concentrations of hydroxide and hydronium.
With regards to Borek, what I know about buffer solutions is that they are mixtures of a weak acid and its conjugate base. I believe the NH4^1+ and NH3 combination constitute a buffer solution. Am I correct.
DING! DING! DING! DING! DING!
Now if you can explain how buffers work you're golden.
Seems like you have just stated that you should include 7 in your final answer.
Okay, so just to make sure, am I correct in thinking that the answer should be number 5 and number 7, since I have a buffer and an acid/base conjugate pair?
I think 3 still can be slassified as correct - NH3 is a weak base, NH4+ is a weak acid, they are both present in the solution.
Alright, thanks a lot guys.
I finally attempted two solutions of the main question to find the pH, including other concentrations. Many of my values are the same or close to same, as yours. My main trouble is that I came up with two different answers for the pH. (This could all be cleared up if I would just refer to the old quantitative textbook to reproduce the main Ka formula that I used to rely on so well). In either case, both pH answers were alkaline.
