Charged concentric metal spheres
The discussion focuses on calculating the total energy stored in the electric field between two concentric metal spheres with radii R1 = 10 cm and R2 = 10.5 cm, where the inner sphere has a charge of Q = 5 nC and the outer sphere has a charge of -Q. The spheres can be treated as a parallel plate capacitor, allowing the use of the formula U = 0.5 x C x (V^2) to find the energy. Key equations include the energy density formula and Gauss' law for determining the electric field strength (E) between the spheres.
  • Understanding of electric fields and potential difference
  • Familiarity with Gauss' law and Coulomb's law
  • Knowledge of energy stored in capacitors
  • Basic concepts of electrostatics and charge distribution
  • Learn how to apply Gauss' law to calculate electric fields in spherical coordinates
  • Study the derivation and application of the energy density formula in electrostatics
  • Explore the concept of capacitance for spherical capacitors
  • Investigate the relationship between electric field strength and potential difference in capacitors
This discussion is beneficial for physics students, electrical engineers, and anyone studying electrostatics or capacitor design, particularly in understanding energy storage in electric fields.
ChrisBaker8
Two concentric metal spheres have radii R1 =10cm and R2=10.5cm. The inner sphere has a charge of Q=5 nC spread uniformly over its surface, and the outer sphere has charge −Q spread uniformly over its surface.
Calculate the total energy stored in the electric field between the spheres. (Hint : the spheres can be treated as flat parallel slabs separated by 0.5cm)
U = 0.5 x C x (V^2)
=(Q x V)/2
Energy Density=1/2 x epsilon_0 x E^2
None, unless confused scribbles count. I know I can treat this as a parallel plate capacitor (from the hint), but that doesn't seem to help me.
I've been looking though my textbooks for hours but I can't find a clear way to work this out. I tried using (Q x d) / (A x Permittivity of air) to work out the electric field strength (E), but I didn't know which area to use for A.
If I can work out the energy density of the field, I can multiply it by the volume of the space between the spheres to find the energy stored, but again, I can't work out E.
Use Gauss' law or Coulomb's law to calculate the field between the spheres:
[tex]\int \vec{E}\cdot dA = \frac{q_{encl}}{\epsilon_0}[/tex]
[tex]E = Q/4\pi \epsilon_0r^2[/tex]
It is not quite, but approximately equal over the .5 cm distance between spheres.
The potential difference between the spheres is V = Ed (in volts or joules/coulomb).
Since potential difference is the energy in joules per coulomb of charge: U = QV
AM
  • · Replies 18 ·
