I proving if a + a = 0 then a = 0
  • Context: High School
  • Thread starter Thread starter jmazurek
The discussion confirms that if a + a = 0, then a must equal 0. The proof utilizes fundamental properties of addition, including the additive inverse and the associative property. By rewriting a + a as 2a and dividing by 2, it is established that a = 0. The conclusion is supported by the additive identity property, affirming that the only solution to the equation is a = 0.
  • Understanding of basic arithmetic properties, including the additive inverse.
  • Familiarity with the associative property of addition.
  • Knowledge of the additive identity property.
  • Basic algebraic manipulation skills.
  • Study the properties of real and complex numbers in depth.
  • Learn about algebraic proofs and their structures.
  • Explore the concept of additive inverses in various mathematical contexts.
  • Investigate the implications of the additive identity in different number systems.
Students of mathematics, educators teaching algebra, and anyone interested in understanding fundamental arithmetic proofs.
jmazurek
I need help proving if a + a = 0 then a = 0. Thanks!
Are you working with ordinary arithmetic, with ordinary (real or complex) numbers? If so then a+a=2a. Thus you have 2a=0. Divide both sides by 2 to get your answer.
Sure, I'd be happy to help you with this proof. First, let's start by assuming that a + a = 0. This means that the sum of a and a is equal to 0. Now, we can use the properties of addition to rewrite this as a + a = a + (-a). This is because the additive inverse of a is -a, meaning that when added together, they cancel each other out and result in 0.
Next, we can use the associative property of addition to rearrange the terms and get (a + a) + (-a) = 0. Now, we know that a + a = 0, so we can substitute this in to get 0 + (-a) = 0. Again, using the additive inverse property, we can rewrite this as (-a) = 0.
Finally, we can use the additive identity property to conclude that a = 0. This is because the additive identity of any number is 0, meaning that when added to any number, it remains unchanged.
Therefore, we have proven that if a + a = 0, then a = 0. I hope this helps with your understanding of this proof. Let me know if you have any further questions.
  • · Replies 21 ·
  • · Replies 34 ·
