Using 3 input LUT's to Implement a Boolean Function
  • Thread starter Thread starter blue2004STi
    Function Input
The discussion focuses on implementing the Boolean function f(w1,w2,w3,w4) = SUM(m(0, 1, 3, 6, 8, 9, 14, 15)) using the minimum number of three-input Look-Up Tables (LUTs). The derived Sum of Products from the K-map includes terms such as (~w1*~w2*~w3) and (w1*w2*~w3). Participants suggest utilizing Shannon's expansion theorem to simplify the implementation process. The goal is to optimize the use of three-input LUTs, each capable of storing 8 values, to achieve an efficient solution.
  • Understanding of Boolean algebra and functions
  • Familiarity with K-map simplification techniques
  • Knowledge of Look-Up Tables (LUTs) and their configurations
  • Proficiency in Shannon's expansion theorem
  • Research the implementation of Boolean functions using three-input LUTs
  • Study advanced K-map techniques for minimizing Boolean expressions
  • Explore Shannon's expansion theorem in detail for circuit design
  • Learn about the design and optimization of digital circuits using LUTs
Students and professionals in electrical engineering, digital design engineers, and anyone involved in optimizing Boolean functions for FPGA implementations.
blue2004STi
Consider the function f(w1,w2,w3,w4) = SUM( m(0, 1, 3, 6, 8, 9, 14, 15)). Derive an implementation using the minimum possible number of three-input LUTs.
Where SUM(m(0, 1, 3, 6, 8, 9, 14, 15)) is the sum of the min terms, a Sum of Products that from a K map is (~w1*~w2*~w3)+(~w1*~w2*w4)+(w1*w2*~w3)+(w1*~w2*w3)+(~w1*w2*w3*~w4) Where ~w is "not w".
Thus far all I can do is get the minimum cost solution from the K map, which I gave above. I guess I'm just a little confused as where to start considering a 3 input LUT has 8 stored values and 3 different inputs and one output. Any help will be beneficial! Thanks,
Matt
Noone have any ideas? I'm not looking for the answer just a push in the right direction. Thanks, Matt
Use shannon's expansion theorem
