Thread Closed
Pencil tipping problem - trying to understand uncertainty
Share Thread Thread Tools
Oct26-09, 09:00 PM   #1
Greetings, I'm new to the forums and just starting grad school. We recently had a homework problem to estimate the amount of time a pencil could stand on its tip without falling over. I remember an undergrad professor mentioning that he had been asked this problem on his orals so perhaps it is common and some of you have seen it before.
In any case, the desired solution was to first solve for the classical equations of motion and then plug in initial conditions based on the uncertainty principle. You assume minimum uncertainty, assume that values of [tex]\dot\theta[/tex] and [tex]\theta[/tex] are approximately equal to their variances, and then optimize the ratio of [tex]\dot\theta[/tex] and [tex]\theta[/tex] to maximize the time before it falls over. This method yields something on the order of a few seconds.
The superficial problem that I have with this is that [tex]\dot\theta[/tex] and [tex]\theta[/tex] are both assumed to be positive. I'm alright with approximating it as one dimensional and saying that [tex]\dot\theta[/tex] and [tex]\theta[/tex] will be on order of [tex]\sigma[tex] away from their centers (in this case 0), but shouldn't it be equally likely that they have opposite sign as positive sign? If they had opposite sign and you maximized the time it took for the pencil to fall based on the classical equations it would be infinite.
The deeper problem I have is that I don't understand how you can just put the uncertainty in the initial conditions. I'm trying to understand how uncertainty effects time evolution, but I'm up against a wall here. I could almost see something like drawing values of p and x from under their distributions, evolving them classically for some small time, drawing new values from their distributions, etc. I know that that isn't correct, but is there any way remotely like this to think about it?
Most of the course so far has been devoted to pure math and we're only just starting to see anything remotely physical now. Sorry if my question is naive but I would really appreciate any insight that anyone has to offer.
Thanks.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Oct27-09, 05:42 PM   #2
Very confusing to use half-QM and half mechanics to solve this, especially since in my mind the uncertainty principle is not extremely well demonstrated like other parts of the theory. How you can obtain some sort of time scale from the position/momentum principle is beyond me!
Oct28-09, 12:58 PM   #3
I remember the pencil-tipping problem very well. The answer is about XX seconds. In the uncertainty principle, δx and δp (or δθ and δθ-dot) are conjugate coordinates, and have no inherent correlation. In addition, δx and δp should be treated as rms (root mean square) uncertainties, meaning that they are inherently positive quantities. So treat δx and δp as initial conditions, and use classical mechanics to calculate the tipping time.
Bob S
Thread Closed
Thread Tools
Similar Threads for: Pencil tipping problem - trying to understand uncertainty
Thread Forum Replies
uncertainty principle, relating the uncertainty in position to the uncertainty Advanced Physics Homework 3
tipping a crate Introductory Physics Homework 1
Tipping a Box... Introductory Physics Homework 2
Tipping something given its center of mass? My LAST homework problem!! Introductory Physics Homework 1
Tricky Tipping Problem; 11 sided figure Introductory Physics Homework 1
