What Makes the Three Generations of Neutrinos Unique?
  • Context: Graduate
  • Thread starter Thread starter wam_mi
    Neutrinos
The discussion revolves around the properties and behaviors of the three generations of neutrinos: electron neutrinos, muon neutrinos, and tau neutrinos. Participants explore questions regarding their mass, interactions, and experimental detection, touching on theoretical and experimental aspects of particle physics.
  • Some participants inquire about the mass of neutrinos and the reasons behind the favorability of transitions between different types of neutrinos, particularly from muon neutrinos to electron neutrinos.
  • There is a suggestion that experimental evidence indicates a preference for the transition to electron neutrinos.
  • Questions are raised regarding the energy requirements for detecting neutrinos, with a note that higher-energy neutrinos have a greater likelihood of interaction.
  • Participants discuss the nature of neutrinos as leptons, which do not interact via strong or electromagnetic forces, leading to their classification as weakly interacting particles.
  • There is speculation about the possibility of making the decay from electron neutrinos to muon neutrinos as favorable as the reverse process, though no specific methods are proposed.
Participants express varying levels of understanding and hypotheses regarding neutrino interactions and properties, indicating that multiple competing views remain without a consensus on several points, particularly regarding the mechanisms of neutrino transitions and detection.
Some claims about the nature of neutrinos and their interactions depend on specific definitions and assumptions that are not fully explored in the discussion. The relationship between energy levels and interaction probabilities is noted but not resolved in detail.
wam_mi
Hi everyone,
I have a few queries about neutrinos. I have recently read that there are 3 generations of neutrinos, namely the electron neutrino, the muon neutrino and the tau neutrino.
Q1: Why are they all massive particles and is it true that it is more favourable to go from muon neutrino to electron neutrino and why is that? Is it something to do with stability or decay? Any experimental evidence?
Q2: As for experimental evidence, do we need to have a lot of energy/power to detect these massive weakly interacting particles? Why is it that they only undergo weak interactions?
Q3: Follow up from Q1, is it possible if we can make the decay from electron neutrino to muon neutrino just as favourable as the process from muon neutrino to electron neutrino? If yes, how do we achieve that?Thanks guys!
Q1: From my understanding, it is only experimental evidence that shows the favourable mutation to electronic neutrino.
Q2: The neutrino are electrically neutral (do not interact with the elctromagnetic force), with incredibly little mass (gravity does affect them). Furthermore, they are leptons (strong nuclear interaction of a nucleus does not work). Therefore, you need a direct hit with a nucleus to be able to detect a neutrino.
Cheers
Why shouldn't they be? :smile: Before there was evidence that they have mass, it was a puzzle why they were apparently massless! It's still something of a puzzle why the masses are so small.
The interaction cross section increases with energy, that is, higher-energy neutrinos are more likely to interact with a "target" than low-energy ones. That's why a lot of neutrino research has been done at accelerators that can produce beams of high-energy neutrinos (10's or 100's of GeV rather than the few hundred MeV that you get e.g. from solar neutrinos).
That's just the way they are. The standard model defines them as part of the weak-interaction sector. They're presumably also affected by gravity, but I don't think that's been studied experimentally at all, except maybe indirectly via cosmological data and theory.
Well, they're leptons, so they don't interact strongly, and they're uncharged so they don't interact electromagnetically. Weak is all that's left.
  • · Replies 22 ·
  • · Replies 87 ·
22K
  • · Replies 32 ·
