Finding the Area of a Hyperbolic Paraboloid
The area of the hyperbolic paraboloid defined by the equation z=xy, constrained within the cylinder x^2+y^2=1, can be calculated using a double integral. The correct limits for integration in the first quadrant are x from 0 to 1 and y from 0 to sqrt(1-x^2). The surface area formula requires the function to be integrated, which is given by the expression sqrt{1+(\partial f/\partial x)^2+(\partial f/\partial y)^2}. It is advisable to convert to polar coordinates for simplification due to the circular symmetry of the problem.
  • Understanding of double integrals in calculus
  • Familiarity with polar coordinates
  • Knowledge of partial derivatives
  • Ability to interpret surface area formulas
  • Study the application of double integrals in calculating areas
  • Learn how to convert Cartesian coordinates to polar coordinates
  • Review the derivation and application of the surface area formula for functions of two variables
  • Practice solving integrals involving circular symmetry
Mathematicians, engineering students, and anyone involved in multivariable calculus or geometric analysis will benefit from this discussion.
Juggler123
I need to find the area of the hyperbolic paraboloid z=xy contained within the cylinder x^2+y^2=1. I know I need to take a double integral but am having real difficulty finding the correct limits, so far I've got that;
[tex]\int dx[/tex][tex]\int dy[/tex]
With the x limits being 1 and -1 and the upper y limit to be sqrt(1-x^2) I'm having trouble finding the lower y limit. Although to be honest I'm not completely sure about the other three limits! Sorry about my awful attempt at Latex-ing I don't know how to do it so couldn't write the limits of the integrals on the integral. Any help would be great! Thanks.
the problem is symmetric by pi/2 so I'd just stick to the (+,+) quadrant and your lower limit is y=0. Then your x limits would be 1 and 0.
The area in the entire domain is then four times the area in a single quadrant.
I have no idea what you mean by
Shouldn't there be some function to be integrated in that? And it probably is NOT
[tex]\int dx\int dy[/tex]
but rather
[tex]\int f(x,y) dxdy[/tex]
Even ignoring the "f(x,y)" the two separate integrals implies that the two coordinates can be separated- which is not the case here- at least not in Cartesian coordinates.
The surface area of z= f(x,y) is given by
[tex]\int\int \sqrt{1+ \left(\frac{\partial f}{\partial x}\right)^2+ \left(\frac{\partial f}{\partial y}\right)^2} dA[/tex]
where dA is the differential of area in whatever coordinate system you are using, in the xy-plane. Because of the circular symmetry I would recommend changing to polar coordinates- where the two coordinate variables can be separated.
