Thread Closed
Deflection of Beams - Rearrange formula [URGENT]
Share Thread Thread Tools
Oct28-09, 08:39 PM   #1
Deflection for a simply supported beam... I calculated the deflection of it to be 9.72mm downwards, but there is a support 6mm from the original position and need to calculate the force on the support...
The original formula for deflection is:
y = - (F x L^3)/(48 x E x I)
where 'x' is just the multiplication symbol.
2. Relevant equations
3. The attempt at a solution
To find the force on the support, I went 9.72-6 = 3.72mm
I substituted 3.72 into the equation above as 'y', now, how do i rearrange the formula to find F?
My attempt:
F = (48 x E x I)/(Y x L^3)
I get 2.212 MPa, this surely can't be right as the original load on top is 80KN. Did I rearrange correctly?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Oct28-09, 08:55 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Is this a beam on 3 supports?
Oct28-09, 09:09 PM   #3
Simply supported, no, not 3 supports, doesn't matter I've figured it out now. Thanks.
Thread Closed
Tags
beam, deflection, force, formula, rearrange
Thread Tools
Similar Threads for: Deflection of Beams - Rearrange formula [URGENT]
Thread Forum Replies
Rearrange this formula please... Calculus & Beyond Homework 1
Deflection of beams problem Engineering, Comp Sci, & Technology Homework 6
please help! solid mechanics problems relating stress, deflection, beams, macaulay's Engineering, Comp Sci, & Technology Homework 20
Bending of Beams - Deflection - Stress - Strain Engineering, Comp Sci, & Technology Homework 1
Deflection of beams General Engineering 2
