Comparing Bound Charges on Cylindrical Dielectric Surfaces
The discussion revolves around the analysis of bound charges on the surfaces of a cylindrical dielectric surrounding a conducting wire. The original poster attempts to demonstrate that the bound charge on the outer surface of the dielectric is equal in magnitude but opposite in sign to that on the inner surface, using principles from electrostatics.
  • Participants explore the application of Gauss' Law and the relationship between electric field, polarization, and bound charge density. Questions arise regarding the assumptions of the cylinder's length and the implications for symmetry in applying Gauss' Law.
Some participants provide guidance on using the displacement field \(\vec{D}\) instead of the electric field \(\vec{E}\) for calculating bound charges. There is an ongoing exploration of the implications of assuming infinite versus finite length for the cylinder and wire, with multiple interpretations being considered.
Participants note the potential ambiguity in the problem setup regarding the length of the cylinder and wire, which affects the application of Gauss' Law. There is also discussion about the relationship between free charge and bound charge in the context of the overall charge distribution.
jmtome2
A conducting wire carrying a charge [tex]\lambda[/tex] per unit length is embedded along the axis of the cylinder of Class-A dielectric. The radius of the wire is a; the radius of the cylinder is b.
Show that the bound charge on the outer surface of the dielectric is equal to the bound charge on the inner surface, except for sign.
[tex]\int \vec{E}\cdot \vec{da}=\frac{Q_{enc}}{\epsilon_0}[/tex]
[tex]\vec{P}=\epsilon_0 X_{e}\cdot \vec{E}[/tex]
[tex]\sigma_{b}=\vec{P}\cdot \hat{n}[/tex]
Using Gauss' Law, we get that [tex]\vec{E}=\frac{\lambda}{2\pi r} \cdot \hat{r}[/tex]
Therefore, [tex]\vec{P}=\frac{\epsilon_0 X_{e}\lambda}{2\pi r} \cdot \hat{r}[/tex]
Therefore, [tex]\sigma_{b}=\frac{\epsilon_0 X_{e}\lambda}{2\pi b}[/tex] on the outer surface and [tex]\sigma_{b}=-\frac{\epsilon_0 X_{e}\lambda}{2\pi a}[/tex] on the inner surface...
These are not equal in magnitude! Can someone explain where I went wrong?
[tex] \sigma_{b}=\vec{P}\cdot \hat{n}[/tex]
is the surface charge density. Multiply it with the inner and outer surface to get the bound charge.
ehild
Ahhh! Thank you! :)
No, Gauss' Law for [itex]\textbf{E}[/itex] involves the total (free and bound) charge enclosed by the Gaussian surface. Since you don't know what the bound charges are, you'll want to use Gauss' law for [itex]\textbf{D}[/itex] instead.
Another valid point
[tex]\vec{D}=\frac{\lambda}{2\pi r} \cdot \hat{r}[/tex]
and therefore, [tex]\vec{E}=\frac{\lambda}{2\pi \epsilon\cdot r} \cdot \hat{r}[/tex]
That's better.:approve:
P.S. To write [itex]\chi[/itex] in [itex]\LaTeX[/itex], use \chi
Cool and thanks for your help
Quick final question:
For the bound charge (on both the inner and outer surface) final answer I get [tex]Q_{bound}=\frac{\epsilon_0\cdot \chi_{e}}{\epsilon}\cdot \lambda L[/tex]
but doesn't [tex]\lambda L=Q_{free}[/tex] , where [tex]Q_{free}[/tex] is the free charge of the configuration?
Isn't the length of the cylinder and wire infinite?
Doesn't say that it is so I just assumed it was length L
But if the length is finite, the field isn't cylindrically symmetric and you can't use Gauss' Law...
urgh... so should I assume that its finite or assume that it is infinite? lol... is there some way of calculating the inner and outer surface bound charge density so that it doesn't matter?
I'd assume it's infinite, and calculate the bound charge per unit length...
sounds good to me, I'm actually asked later to calculate the net charge per unit length so I'll need that.
And since we are on the topic... :) to get the net charge per unit length at r=a, [tex]\frac{Q_{net}}{L}=\frac{Q_{free}}{L}+\frac{Q_{bound}}{L}[/tex]? I'm told that the answer is [tex]\frac{Q_{net}}{L}=\frac{\lambda}{\epsilon_r}[/tex].
However...
With [tex]\frac{Q_{free}}{L}=\lambda[/tex]
and...
[tex]\frac{Q_{bound}}{L}=\frac{\epsilon_0\chi_{e}}{\epsilon}\cdot \lambda=\left(1-\frac{1}{\epsilon_{r}}\right)\cdot \lambda[/tex]
the only way I can get the given answer is if I subtract the net bound charge per unit length from the net free charge per unit length... what am I missing?
I thought the bound charge at [itex]r=a[/itex] was negative...:wink:
That's it! I always miss the small things, thanks
  • · Replies 29 ·
