Simplifying $\frac{a}{2^a}$ - Limit to 3/4?
  • Thread starter Thread starter nobahar
    Simplifying
The discussion revolves around simplifying the expression $\frac{a}{2^a}$, which is part of a limit involving a summation as $n$ approaches infinity. Participants are exploring whether this limit tends to 3/4 and are examining the behavior of the function through various mathematical approaches.
  • Mixed
  • Participants are attempting to simplify the expression and relate it to a limit involving a summation. Some are exploring calculus techniques, including derivatives and integrals, while others are questioning the convergence of the series and the equivalence of the summation and integral forms.
There are multiple lines of reasoning being explored, including the use of integration by parts and the Integral Test for infinite series. Some participants have provided insights and partial results, but there is no explicit consensus on the final approach or outcome.
Participants are navigating through calculus concepts, and there is an acknowledgment that the problem may be more advanced than initially thought. The discussion reflects a range of understanding and familiarity with the relevant mathematical tools.
nobahar
Is it possible to simplify this?
[tex]\frac{a}{2^a}[/tex]
It's actually part of a limit:
[tex]2\lim_{n\rightarrow\infty}(\sum_{a=4}^{n}\frac{a}{2^a})[/tex]
The limit I'm hoping tends to 3/4 as n tends to infinity. It certainly appears to do so when I plotted a graph of a/(2^a).
Any little hints? Tried logs but got nowhere: I still end up with an 'a' on the top and bottom. I'm assuming that I need to elliminate it from either the numerator or the denominator.
Thanks in advance.
Okay, I got:
[tex]10^{\log{a}-a.C}[/tex]
Where [tex]C=log{2}[/tex].
I don't know what to do with this.
Does this help:
[tex]\frac{d}{da} \left ( \frac{-1}{2^a} \left ) = \frac{a}{2^{a + 1}}[/tex]
I couldn't get the same result. I got:
[tex]\frac{d}{da} \left (\frac{-1}{2^a} \left ) = \frac {d}{da} (-1 * 2^{-a}) = \frac{\ln {2}}{2^a}[/tex]
Because:
[tex]f(a)= \frac{-1}{2^a} = -1 * 2^{-a}[/tex]
[tex]\ln {f(a)} = -1 * -a * \ln {2}[/tex]
[tex]\frac{d}{da} \left (\ln {f(a)} \left ) = \ln {2} * \frac{d}{da} (a)[/tex]
[tex]\frac {1}{f(a)} * \frac{d}{da} f(a) = 1 * \ln {2}[/tex]
[tex]\frac{d}{da} f(a) = f(a) * \ln {2} = \frac{-1}{2^a} * \ln {2} = \frac{-\ln {2}}{2^a}[/tex]
Is my calculus out?
Am I trying to establish the following?:
[tex]\int_4^\infty (\frac{a}{2a}) da[/tex]
Any help much appreciated, thanks so much for the responses.
Wolfram alpha says you are right:
http://www.wolframalpha.com/input/?i=d(-1/2^a)/da
You could approximate
[tex]2 \sum_{a=4}^{\infty}\frac{a}{ 2^a}[/tex]
by this integral:
[tex]2 \int_4^{\infty} \frac{x dx}{2^x}[/tex]
assuming that both converge.
Thanks for the replies guys!
I'm really sorry, I don't understand.
I thought
[tex]\sum_4^\infty \left (\frac{a}{2^a} \left )[/tex] would be a less accurate approximation of [tex]\int_4^\infty \left (\frac{a}{2^a} \left ) da[/tex];
and that
[tex]\int_4^\infty \left (\frac{a}{2^a} \left ) da = \int_4^\infty \left (\frac{x}{2^x} \left ) dx[/tex] when [tex]a = x[/tex]
That is, are they not the same?
I'm assuming they do as you have suggested it! But how do I make a safe assumption that this is the case?
Thanks again!
There's the Integral Test for infinite series...
BTW, this is not a Precalculus problem. It should be in the Calculus and Beyond section.
Thanks, I'll look it up. Might need to wish me luck!...
Apologies, but I didn't know that it would entail calculus.
Once again, thanks for all your help!
by this integral:
How do I go about doing this? It's difficult to integrate the function. I tried the easy way out by using the calculator but that didn't work.
Change to [tex]2 \int_4^{\infty} x e^{-x ln 2}dx}[/tex]
This can probably be done by integration by parts, with u = x, and dv = e-x ln2dx. That's how I would start.
Also, since this is an improper integral, you would need to take a limit:
[tex]2 \lim_{b \rightarrow \infty} \int_4^b x e^{-x ln 2}dx}[/tex]
Thanks Mark, it seems you always come to my rescue.
Do I integrate first with the limit present for b?
i.e. [tex]\int_4^b x e^{-x ln 2}dx}[/tex], then employ the limit?
I am not familiar with this, it's more 'advanced' than what I have come across so far.
I'll go away and have a crack at it tomorrow, start afresh. (It's fairly late in Merry Old England.)
Once again, thanks for the continuing help.
Yes, integrate first, which will give you an expression involving b. Then take the limit.
lol sorry about that nobahar, my mistake.
No problem!
I attempted to integrate the function:
[tex]\int xe^{-x \ln{2}} dx = \frac{x * e^{-x \ln{2}}}{- \ln{2}} \left \left - \left \left \frac{e^{-x \ln{2}}}{(\ln{2})^2} = \left - \left \frac{(\ln {2})^2 * x * e^{-x \ln{2}} - e^{-x \ln{2}} * \ln{2}}{(\ln{2})^3} = \left - \left \frac{\ln{2} * x * e^{-x \ln{2}} - e^{-x \ln{2}}}{(\ln{2})^2}[/tex]
(Including +C)
Is this correct so far?
Attempt to 'simplify':
[tex]\left - \left \frac{e^{-x \ln{2}}(\ln{2} * x + 1)}{(\ln{2})^2}[/tex]
Assuming that you did integration by parts correctly (I didn't check), and that you ended up with this, about the only thing I can see to do to simplify it is replace e-xln2 with 1/2x.
I'll post the workings.
[tex]\int xe^{-x \ln{2}} dx[/tex]
[tex]u = x \left \left and \left \left \frac{dv}{dx} = e^{-x \ln{2}} \left \left then \left \left \frac{du}{dx} = 1 \left \left and \left \left v = \int e^{-x \ln{2}} dx = \frac{e^{-x \ln{2}}}{- \ln{2}}[/tex]
[tex]\int xe^{-x \ln{2}} dx = \frac{xe^{-x \ln{2}}}{- \ln{2}} \left \left - \left \left \int \frac{e^{-x \ln{2}}}{- \ln{2}} dx = \frac{xe^{-x \ln{2}}}{- \ln{2}} \left \left - \left \left \frac{e^{-x \ln{2}}}{(\ln{2})^2}[/tex]
Okay, so:
[tex]\frac{x \ln{2} + 1}{2^x(\ln{2})^2}[/tex]
Now I need:
[tex]\lim_{b \rightarrow \infty}[\frac{x \ln{2} + 1}{2^x(\ln{2})^2}]^{x=b}_{x=4}][/tex]
I don't know how to do this. Where would I start?
It seems to me that JG89's comment is in the right direction of the usual way to work this problem. It does involve a trick that you'll need to see spelled out in detail. Remember it and use it to solve similar problems. Consider for some positive integer [itex]n[/itex] the function
[tex]f(x) = \frac{x^n}{2^n}[/tex]​
It is everywhere continuous and differentiable, and its derivative is
[tex]f'(x) = \frac{n}{2^n}x^{n-1}[/tex]​
Next, consider the sum:
[tex]F_n(x) = \sum_{a=4}^n \frac{x^a}{2^a}[/tex]​
so that we have a geometric series, i.e.
[tex]F_n(x) = \sum_{a=4}^n \frac{x^a}{2^a} = \frac{x^4/16 - x^5/2^{n+1}}{1-x/2}[/tex]​
The final step is to take the derivative:
[tex]F'_n(x) = \sum_{a=4}^n \frac{a}{2^a}x^{a-1} = \frac{(x^3/4-5x^4/2^{n+1})(1-x/2) + 1/2(x^4/16-x^5/2^{n+1})}{(1-x/2)^2}[/tex]​
Notice that
[tex]\lim_{n \rightarrow \infty} F'_n(1) = \sum_{a=4}^\infty \frac{a}{2^a} = 5/4[/tex]​
is the limit that you are looking for.
That's truly amazing. Many, many thanks Tedjn. Initially, it's a little hard to follow because the derivative is of the variable x, but then you take the sum of a. But I think I understand it. I'll work through it again.
Once again, many thanks.
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 17 ·
